Question about Sharp XR-10X Multimedia Projector
Nothing happens.. Our projector just completely stopped working. We were in the middle of a movie and it just shut off. Will not come back on. What could the problem be, and how can we try to fix it ourselves?
  • 1 more comment
  • ChanceM Nov 18, 2007
    The same thing happened to us last night.
    Help would be apprecaited.
  • Anonymous Dec 25, 2007
    Same problem. Picture just stopped. It wasn't the lamp, b/c no lights. I was thinking it might be a fuse. Of course it is X-mas and Radio Shack is closed. Thanks for the instructions!
  • earth5worker Dec 31, 2007
    My Sharp XR-10x projector has same problem. Just stopped working while we were using it. Doesn't seem to be getting any power.
    I followed instructions provided in previous post (incidentally, great instructions. thanks) and got to the fuse. However, I did a continuity test on the fuse and it appears to be ok (not blown). Will replace anyway, but don't expect this will solve my problem. In anticipation, wondering what else may be at fault?
    This is the second such projector I've purchased. So far, no problem with the first. Difference may be attributable to the fact that problematic projector was ceiling mounted (ie. upside down). Perhaps in that position the fan setting should be set to high (default is 'normal'). Don't know. Just a guess.
    Problem Solver:
Once you open the unit, try pressing the little red button on the lamp casing (towards the front of the unit). That's what fixed my problem (with identical symptoms).
Posted on Jan 01, 2008
I had the same problem and I just fixed it. Here is what you need to do.
Unscrew all of the bottom screws (you will need a long screwdriver)
Unscrew all of the back screws near the inputs
Carefully but FIRMLY pry and remove the top of the case (it is hard but you will get it)
Remove all of the screws on the metal case and circut board. Unconnect all of the wires (mark them so you can plug them back in)
PULL THE CIRCUT BOARD OUT- this will also take pressure as it is connected to the lamp/lens.
Unscrew the metal plate/case. This is a pain as there is one screw that is on the side and IMPOSSIBLE to remove with a screwdriver. I used needlenose and twisted it out.
Once removed look towards the plug through the hole and you will see a standard fuse. I used the needle nose again to remove it.
Run down to Radio Shack and get a 6.3 AMP 250 W fuse
replace and put everthing back together.
DO NOT FORGET TO TAKE EXTRA CARE TO GET THE CIRCUT BOARD CONNECTED TO THE LAMP/LENS INPUT!!! It is on the bottom of the board and takes a little finesse.
Power on and you should be good to go.
I managed to fix mine for about $2.99 plus gas and about 2 hours of time. If I did it again it would take me 20 minutes...
Good Luck!
Posted on Dec 13, 2007
Turned on the projector and it immediately shut down and now has no power
it seems that the lamp ballast is failing
We supply original projector lamp,bulb,accessories,Lcd panel,Lens,DMD
chip,color wheel,motherboard,powersupply,ballast... with high quality and
competitive price.
any questions, feel free to contact me
have a nice day!
Jerry,Lampdeng Limited
Mar 09, 2014 | Boxlight Cinema 13HD Lamp
My Sharp XR-10X unit just suddenly stopped working in the middle of a presentation. No lights, no sound, nothing. Any ideas? I've tried to open up the cover, but with no luck. How can I open up the back...
Most likely cause of the problem is termo protection, it has to be reset. I would not recommend you to open the projector by yourself. You simply wouldn’t know what to do with it.
Feb 08, 2010 | Sharp XR-10X Multimedia Projector
Shutting down in the middle of presentations
it's overheating from excessive dust or lack of air flow. blow the dust out of it with canned air and make sure all of the vents are free from obstructions.
Feb 02, 2010 | Sharp PGF312X DLP Projector
Optoma DV10 randomly shuts off completly during a
check the power timer settings and put it to disable setting, Or avoid anything that cover the exhaust, fan if the problem occur get assist to the technician.
Oct 22, 2009 | Optoma MovieTime DV10 Multimedia Projector
My sharp xr-20x projector wont turn
are there any leds on? if not, the power supply is shot. if there are leds on, the color and number of flashes will tell you the problem.
Aug 12, 2009 | ViewSonic PJ402D DLP Projector
Black dot appears in middle of screen when watching a movie
we changed out the light buld... now it works fine.. funny thing was projector was brand new just out of box... you could see first thing there was a brown spot in the center of the buld creating the spot apparently after it heated up.... thanks again
Aug 05, 2009 | Sharper Image 1617293 Projector
Nothing comes on except the green standby light on PT-AE900E.
I have the same problem. It seems we have to reset the counter. This reset must be done via the beamer itself and not via remote control, since lamp is not working...
Jul 24, 2009 | Panasonic PT-AE900U Multimedia Projector
No power
there are six screws in the base and two in the back of the unit. After taking off the top I saw a red button on the front that was a little pushed out - I pushed it in and I got the led lights back :)
Jun 22, 2009 | Sharp XR-10X Multimedia Projector
VPL-HS20 shuts down in the middle of a movie
There is a heat sensor cutting down the power. The sensor is located on the upper side between lamp and fan and is monitoring the air temperatur. I don't know what is causing the sensor to switch - excessive heat or simply age or ... . Anyway un screwed this sensor and my problem disappeared.
Possibly a stronger fan would solve the problem too.
Jun 26, 2008 | Sony VPL-HS20 Multimedia Projector
Sharp XR-10X Multimedia Projector Logo
96 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
