This error, special when it happens with more cards, could be indicating, one or more contacts in the camera are dirty or oxidised. Almost impossible to clean, if you don't know where there are seated. Just put in and remove the card several times is my hint.
Take care you don't damage any contact.
Then you could try to format every card you insert in the camera.
Not many people know, it is needed for a correct working of the card, that it is formatted in the camera it is used. Even two camera's from the same brand and the same type, can have trouble with the format of the other camera.
Make sure there is no map on the card, or a picture with a high number like 99, 999 or 9999.
SOURCE: "Memory card is full"
This error message indicates that there is no more space on the memory card in the camera. To resolve this problem, do one of the following: Turn off the camera and insert a new memory card. Transfer or delete pictures from the memory card. Change the storage location to use the internal memory.
SOURCE: Memory Full Error
to use a memory card u have to check the manuel probably u have to buy an mmc card for storing pictures and videos as it is an sd card u have to first dormat it u can do it inside a mobile phone also
SOURCE: Memory card flashes full when it's not
There should be a "format card" option in the camera's system menu. do this and it may help the unfortunate equipment realize the situation:) (be sure there are no pics you want to keep as they will be permenantly removed)
SOURCE: Memory full; how to clear
Sounds like you will need to format the internal memory of the camera. This will permanently erase all the data from the internal memory and then you will be able to use it again. To format the memory: Remove the xD card from the camera - Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the memory so it can be used again.
SOURCE: say's the memory card is full. It is a new empty (kodak cw330)
You may need to go into the Menu Selection of the camera & locate the "Format" option. Choose Format & see if it will then read the card.
