With the lock screw removed (it's a reverse threaded screw) you can procede with getting the chuck off the drive shaft.
OK, you need to put a 1/4" or larger hex key wrench into the chuck and tighten it in place with the chuck key. Put the short end into the chuck.
Once you've done that, place the drill chuck, only the smooth part, not the part with the teeth, on the edge of a solid workbench. Now hold the chuck with the hex key (long end) at a 30 degree angle off the bench top and strike the hex key with a hammer going counterclockwise (looking at the front of the tool) to loosen the right hand threads that hold the chuck to the shaft (spindle). You should now be able to easily remove the chuck by hand at this point.
Here's link to a manual for your Hole Hawg that will also show a nice illustration of the removal method, to make it a bit easier, as well as giving you other good info about your drill. Print a copy for your files and future reference.
That should do it! Hope you find this Very Helpful and best regards!
Was this helpful?
Yes
No
2 people thought this was helpful
Asker's Testimonial
I tried this before i posted the question But it did not work. I thought it might be a pressed on chuck But i guess I just need a bigger hammer. thank
" - superdavid
Popular Solutions for Milwaukee 1670 1 Drill 1/2 900
I need to drill the rear lock pin of an X-08 lock and was wanting to know how deep do I have to...
(More)
I need to drill the rear lock pin of an X-08 lock and was wanting to know how deep do I have to drill to remove the pin? I ordered the drill template from Lockmasters and I have the 1/8 drills bits. Thanks Lee
I just bought 2 ADEMCO 5804 Key Fobs for my ADEMCO LYNXR-EN Security System. Does anyone have an...
(More)
I just bought 2 ADEMCO 5804 Key Fobs for my ADEMCO LYNXR-EN Security System. Does anyone have an idiots guide to step-by-step procedure for programming the Fobs to my Alarm? I do not have the installation manual for my Security System.
