Question about Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum
Direct Drive System on Kenmore 31913 Vacuum
Will not operate in self propel mode
You need to reset it on the front. overload reset button
Posted on Dec 11, 2007
Manual for Kenmore Progressive Direct Drive Upright Vacuum
can some one show via picture of the location where the micro switch is where the hose attaches to the progrssive direct drive vacuum cleaner to get the start brushes rolling again,
Sep 28, 2010 | Kenmore 31913 Progressive Direct Drive...
My purple proggesive kenmore upright motor works but beater not beating help thank you
I just had the same problem - reset button didn't trip - cleaned the roller - ultimately found there is an override switch at the point where the hose attaches to the base of the vacuum - it disables the roller when you use the attachments. The hose had become loose (but not disconnected) enough to trip the switch. An easy fix after alot of tinkering... p.s. All those "experts" that said to change a belt obviously don't understand that this model is beltless...
Nov 09, 2009 | Kenmore 31913 Progressive Direct Drive...
Need Manual for Kenmore Progressive with Direct Drive vacuum clea
You can check for the manual at:
www.managemyhome.com
I would suggest checking the hoses for clogs. Especially the hose right after the carpet brushes. Don't forget to clean off your brush. Hope this helps.
Jan 12, 2009 | Kenmore 31913 Progressive Direct Drive...
Need owners manuel kenmore progressive direct drive model 116.35923500
You can get the manual at:
Just do a search on the right side.
Dec 30, 2008 | Kenmore 31913 Progressive Direct Drive...
Need manual
Here is the manual that you need.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0403208.pdf
Good Luck and Please Rate FixYa!
Dec 29, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive model 116 31912100 lost vacuum
Check the inlet where the dirt is first sucked in for a clog, also your hose may be clogged.
Sep 01, 2008 | Kenmore 31913 Progressive Direct Drive...
Kenmore progressive Direct Drive Vacuum w/Hepa
Check the hose and dirt inlet for a blockage. Also the brush roll, check it to see if you can turn it or not by hand. If not, then something may have jammed it.
May 03, 2008 | Kenmore 31913 Progressive Direct Drive...
Beater bar works intermittently
When you push the hose into the tube, there is an acuator that will push the switch so the beater bar will turn. That switch could be just dirty, dust gets in them and they won't always work, the acuator may need to be replaced. Either that or you have a bad wire connection somewhere in the noozle or where the wires just go into the noozle asm.
Apr 13, 2008 | Kenmore 31913 Progressive Direct Drive...
Self Propel
Determine if the wheels spin freely or if there is resistance. Sounds like you need a replacement belt for the drive. If you need help with installation, let me know.
Oct 29, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore direct drive will no longer self-propell
There may also be a reset button. If the brushes get stuck the unit can shut off power to the brushes to keep a total melt down from occurring. The reset button should return power in these types of vacuums.
Aug 17, 2007 | Kenmore 31913 Progressive Direct Drive...
Kenmore 31913 Progressive Direct Drive Bagged Upright Vacuum Logo
306 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
