Question about Kenwood VR-209 Receiver
How can I rename the Video outputs on VR-209
The inputs currently read
Video 1
Video 2
DVD
However I have Satellite hooked up to Video3 (DVD) and DVD hooked up to Video 2.  I need to rename these 2.
Follow this link http://www.scribd.com/doc/3280749/Kenwood-VR209-VR209pdf-Owners-Manual-English and go to page 15.
Posted on Feb 20, 2009
How to use without remote
UPC 961613194763 053818570722
  • HDMI Output (rear), Remote control, Plays DVD Video, DVD_R/RW (VR format), DVD-R/RW (Video format), CD-R/RW, Audio CD, MP3)
  • MAGNAVOX ZV427MG9 DVD Recorder / VCR Combo LINE-IN RECORDING (NO TUNER)
  • 1080 Up-Conversion, Progressive Scan Video Out
  • Five Speed for up to 6-Hours Recording, Dolby Digital Stream Out
  • 2-Way Dubbing (VCR > DVD, DVD > VCR), Satellite Link Recording, S-Video Input / Output
  • Dec 02, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
    I have a VR-407 reciever and I am unable to get my CD/DVD rear outputs to work. I am hooking up a DP-3020 and I can get it to work in the Audio L/R jacks in the front. Is there something that I need to do...
    A Kenwood VR-407 is a receiver and has an INPUT pair for CD/DVD, not outputs. Plug ANY functioning audio source (except a turntable) into it and select it on the front panel.
    If your DP doesn't work on either I'd suspect something is wrong with IT.
    May 24, 2011 | Kenwood VR-407 Receiver
    I need to hook up my Kenwood vr-207 to a satellite HD receiver and blue ray player. How do I hook up the component cables. I am not sure where to plug in the "in's" and "outs".
    In's always go to Out's.
    The VR207 has no component video inputs, just a composite video output so you can use your TV for the receiver's On Screen Display.
    http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/vr207.pdf
    Just run your BluRay and Cable box HiDef HDMI, component, s-video, composite video, whatever (in that order of preference) to a matching input on your TV or monitor.
    As a rule you should run the best audio from each of your video sources to the VR. There is no compelling reason to ever send good audio or video to a device that has little (or no) use for it.
    Unfortunately, the VR207 has no digital audio inputs, so the best it can muster regarding surround is Dolby Pro Logic derived from 2-channel inputs.
    BUT, if you have a DVD, BLURAY player or cable Box with 5.1 analog outputs you can let their internal circuitry decode Dolby Digital programming to true 5.1 for input ("DVD/6CH") to the VR207.
    Feb 05, 2011 | Kenwood VR-207 Receiver
    I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
    that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
    you can still use it, but if you run the picture through the reciever, it will have poor quality.
    heres how you are supposed to hook it up:
    find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
    finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
    Nov 25, 2010 | Kenwood VR-6050 Receiver
    How to hook up a kenwood audio-video surround receiver vr-405 to a 46" Bravia tv?
    hello all you need is a good pair of RCA cables.
    Use the audio output on the TV
    run it to the VIDEO 1 input on the receiver
    as for your DVD player vcr etc you can either run them directly to the tv as it will output whatever sound is playing to the receiver.
    or
    use the receiver as a video switcher and connect your components directly to it.
    remember your receiver will need to be set to the input you use. ie: video 1 / dvd etc..
    Hope that helps
    Jan 10, 2010 | Kenwood VR-405 Receiver
    I need to get to video3,it stays on 1 which is for the sat. My dvd is hooked up to video 3.
    On the remote press the TV/Video key repeatly until the desired video input is selected.
    Dec 15, 2009 | Sony KV-32V16 TV
    In spite using DVD-R disks with the specified logo (in the case, Memorex and Sky), as I insert them in the recorder, it formats the disk but doesn't record anything on it and, when I try to eject the...
    ?Ÿ???¾?±?»?µ?¼?° ?µ ?²??µ?¾?±?? . ?¢????±?²?° ?´?° ??µ ??¼?µ?½?¸ ?¿?¸??°?????°???° . ?¢? ?µ ???¾?¼?¿?Ž???Š???½?° , ?¾?¿?¸???²?°?¼ ??µ , ?½?¾ ?½?µ ?µ ???°?·?¿?¾?·?½?°?²?° . ?¢????±?²?° ?´?° ??µ ?½?°?¼?µ???¸ ?½?°???¸?½ !
    Nov 03, 2009 | Sony RDR-HX1000 DVD Recorder
    Problems establishing audio output from DVD RW to TV
    If you own a Digital Video Recorder, such as TiVo, or a DVR from a Cable or Satellite provider, then you know you can record to the device's hard drive to view TV shows at a later time, much like the old VCR. However, saving those TV shows becomes difficult as the Hard Drive starts to fill up. The answer to saving your shows is to record them to DVD! This can be accomplished easily by hooking up a DVD Recorder to your DVR
    Here's How:
    1. 1)record a TV show on your DVR that you want to save to DVD!
    2. 2)Turn on the DVR, DVD Recorder and the TV that the DVD Recorder is connected to. In my case, I have my Samsung DVD Recorder (no hard drive) hooked up to my TV via an RCA Audio/Video cable from the rear outputs on the DVD Recorder to the rear RCA inputs on my TV. I use a seperate DVD Player for playing DVDs, but if you use your DVD Recorder as a player as well, use the best cable connections you can to connect to the TV. See the articleTypes of A/V Cables for more info.
    3. 3)Connect an S-Video or RCA video cable and composite stereo cables (red and white RCA plugs) from the DVR to the inputs on your DVD Recorder. If your TV has Component inputs, connect the Component Out from the DVD Recorder to the Component In on the TV, otherwise you can use S-Video or Composite. You will still need to use RCA audio with your video connection.
    4. 4)Change the input on your DVD Recorder to match the inputs you are using. Since I'm using the rear S-Video input, I change my input to "L1", which is the input for recording using the rear S-Video input. If I was recording using the front analog cables it would be "L2", the front Firewire input, "DV". The input select can typically be changed using the DVD Recorder remote.
    5. further instructions continued in my next comment post please read.
    Apr 05, 2009 | Sharp Televison & Video
    VR-206 - how to wire in equalizer
    your vr-206 have several inputs dvd, vcr, tape decks, turn tables etc, also have an opcion called eq in and out usually if you dont have an equalizer al you do is jump straight rca to rca cables red in to red out and white in to white out.
    but if you have an eq all you do is output from amp vr-206 to input and the input to output back to the amp
    Dec 22, 2007 | Kenwood VR-209 Receiver
    Kenwood VR-209 Receiver Logo
    144 people viewed this question
    Top Kenwood Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Don Hart
    Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
