Dyson DC39 Multi Floor Ball Canister Vacuum New - Authorized Logo
S
Sam Khoshkholgh Posted on Mar 09, 2014
Brush no longer spins
I have a a trigger head turbine control DC39 and the brush does not get engaged to spin at all. this happened after I washed the head. There is no red button on this brush or the vacuum itself to reset.
fazil mohamed
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Mar 09, 2014
fazil mohamed
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
0
Helped
6135
Points
34
Apply some Oil or crease in it to lubricate it! it will surely work
5 Related Answers
Anonymous
  • 120 Answers
  • Posted on Sep 17, 2008
SOURCE: brush and belt no longer rotating
you probablly need a new belt clutch it should go to a vac shop it isnt an easy fix
rustysheriff
Tony Groves
  • 344 Answers
  • Posted on May 17, 2010
SOURCE: The spinning brush isn't moving
Belt may be off the motor spindle, with the vacuum off try turning the brush by hand, does it turn freely or can you feel the resistance of the motor?
Anonymous
  • Posted on Sep 08, 2010
SOURCE: Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
askdyson
AskDyson
  • 2572 Answers
  • Posted on Jun 07, 2011
Official advice and support for Dyson technology
    Verified Fixya Pro
    SOURCE: Dyson DC24 brush no spinning.
    Hi, it's Jack from Dyson.
    You may find it useful to try pressing the button in as far as it will go - this should resolve this issue for you.
    However, if you're still experiencing difficulties, please get in touch with us, free, on 08002980298 (UK), or 1866MYDYSON (US), and we can run through some checks with you over the phone.
    Kind regards,
    Jack
    Dyson Customer Service
    askdyson
    AskDyson
    • 2572 Answers
    • Posted on Aug 12, 2011
      Verified Fixya Pro
      SOURCE: brush inside main head doesn't spin, and stops
      Sorry to hear you're having difficulties with your DC14. If the brushbar won't run when the cleaner is in contact with the carpet, it's probably best if you get in touch with us directly. One of our experts will be happy to run through some troubleshooting over the phone with you, and recommend the best course of action. You can call us free on 08002980298 (UK), or 1866MYDYSON (US). We'll look forward to hearing from you.
      Kind regards,
      Jack
      Why does the DC39 canister triggerhead does not spin when vacuuming?
      Check for clogs in the turbo head, wand and hose.
      Oct 31, 2019 • Vacuums
      1helpful
      Turbo head has stopped spinning
      Hi Fay, it's Jack at Dyson.
      If your DC39 Multi Floor's turbine head has stopped spinning, this could mean there's a blockage in the turbine head, wand, hose or lower duct hose. This could reduce the airflow passing through the machine, which in turn will affect the turbine which powers the rotating brush bar.
      It's also a good idea to check the Turbine head is free of any threads, hair or other obstructions:
      If you need further help once you've given this a go, you can reach our experts at the Dyson Customer Helpline by calling 1-866-693-9766 (US), 1-877-397-6622 (CA) 1800 239 766 (AU), or 0800 298 0298 (UK).
      I have used my dyson dc39 perhaps a dozen times tops and the brush bar won't stay spinning. I've stood it upright and turned it off, clicked the brush power button. Spins then stop-makes pop sound.
      If it's like my DC-07, the brush shouldn't spin if it's upright, and also won't spin if you don't have the clutch for the brush fully engaged. Make sure that the back of the unit is tilted off of the fully upright position, and check that the brush clutch is all the way engaged - there may seem to be a middle setting, but that isn't really where you want to be. Hoping that helps.
      Why won't the brush on the head stop spinning?
      Hi Glen, it's Jack at Dyson.
      Depending on which DC39 variant you own, you may have the facility to shut off the rotating brush bar using the trigger control on the hand grip. The brush should be shut off when cleaning hard flooring, delicate rugs or long pile carpet. Press and hold the button for a few moments to shut off the brush bar:
      If you've tried this and cannot shut off the brush bar, please contact the Dyson Customer Helpline directly. Our experts will need to take some further details about your particular machine, and will also be able to talk you through some simple troubleshooting checks to resolve any issues.
      You can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
      Brush bar doesn't spin on dyson on dc39
      Hi there, it's Jack at Dyson.
      DC39's Trigger head floor tool is powered by a turbine, driven by your vacuum's suction. Following these simple checks should help you resolve any issues which could be preventing the brush bar from rotating as normal: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar/dc39-check-triggerhead-tool
      If you'd like further help from our experts after giving this a try, please get in touch with us directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU). If a replacement part is needed, we can also confirm if this is covered under your Dyson parts and labour guarantee.
      Get the brush bar to spin again on my dc39 vac
      The rotating brush bar inside DC39's Triggerhead floor tool should rotate when the vacuum is running, unless you turn it off using the button on the wand handle. If it's not rotating, our Support guide will walk you through the checks needed to resolve this: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/trigger-head-not-working/dc39-check-the-brushbar
      In the unusual event that these checks don't resolve the issue, please contact our experts directly so we can help you further. You can reach the Dyson Customer Helpline by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
      3helpful
      2answers
      The turbine head of my DC39 stopped working. The suction is super, took the brush out and disconnected the hose and looked into it, no blockage is visible looking. ideas?
      hi russ, it's jack at dyson.
      i'm sorry to hear you're having difficulty with your dc39's triggerhead floor tool. i appreciate you've already checked for a blockage, but you may want to follow the steps shown in our online support guide just to make sure there's nothing you've missed: http://www.dyson.co.uk/support/dc39/dc39-animal/machine-is-not-working/dc39-check-extension-tube
      if you find there's no improvement after running through these checks we're happy to help further - and if a replacement is needed, we can confirm if this is covered under your dyson warranty. you can reach our experts directly by calling on 0800 298 0298 (uk), 1-866-693-9766 (us), 1-877-397-6622 (ca) or 1800 239 766 (au).
      2answers
      Dc 39 canister carpet brush will not turn
      on the head there is a round filter type part if that is pushed in the the brushes won't turn. try pulling it out slightly.
      Turbo head on DC39 animal will not spin. I have removed any hair etc caught around the brush but still no spinning..
      I have the same problem with my DC39 Animal's brush bar. Im on my 3rd one in 9 months of ownership. The DC39 brush bar is driven pneumatically (there is no electric motor in the brush head) and switched on and off via a suction activated pneumatic ratchet within the brush head. The moving components are actuated by bellows. Ive found that the glue holding the bellows fails stopping the ratchet working intermittently at first and then completely as the bellows comes away completely. At first you can help the ratchet by tapping the brush head - the red ratchet ring can be seen to click round. This, in my opinion, is an inherent weakness of the DC39 design and cannot be easily repaired. The only solution is a new brush head. Luckily Ive got a 5 year warranty and at the current rate I will have got through about 20 brush heads !
      Top Dyson Vacuums Experts
      AskDyson
      AskDyson
      Sean Wright
      Sean Wright
      xxxxxx xxx
      Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
