Sony Playstation 3 (PS3) Console Logo
m
martin moir Posted on Mar 09, 2014
Discs not spinning - Sony Playstation 3 (PS3) Console
Daniel Pascarelli
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Mar 10, 2014
Daniel Pascarelli
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
970
Points
9
If the disc is not spinning in your PS3 than that means the disc drive is broken. Your best bet would be to contact sony if your PS3 is still under warranty so they could fix it, or just buy your games digitally and play them without the disc.
1helpful
Sony cdp-c215 wont read disc removed cover disc doesn't spin
The pladder motor that spins the disc is open, or the laser pickup is defective, the whole laser assembly would need to be replaced, not cost effective to repair cheaper to buy.
1helpful
2answers
Cd wont spin
The pladder motor is bad, "disc sits on top" most be replaced to regain normal operation.
1helpful
2answers
I purchased a toshiba portable dvd player and the disc is not spinning therefore reads no valid disc. I have put in a few discs still same reading? Any suggestions?
Hello
The Sled Motor is defective. this is the motor, whic spins the disc as it has been loaded properly. If the loader mechanism loads the disc properly into place and if the catch up magnet catches the disc in place, and still the dis do not spins, replace the sled motor. OK.
Disc doesn't spin
Hello
Check whether the disc inserted into the player spins. If it does not spins, replace the sled motor.
The CD player will play some purchased CD-s but will not play others. The ones that it will not play do NOT iniate the disc motor but a click is heard and the display reads NO DISC. I have cleaned the...
If you can disassemble the CAP(disc holder) and place it on the disc while it is on the spindle and at the same time push the (hidden)lid switch you will see the lazer"s lens move up and down while trying to focus on the disc. If the lazer see's the disk it will tell the motor to turn. If it dosn't see the disc it will not turn the motor. Some model will kick the disc to spin a little while trying to see the disc. This type of player can be tricked into seeing the disc if you spin the disc a little by hand when the lazer's lens is moving up and down. At that point in time it might see the disc and take over the motor and spin up to normal speed. If the disc is an illeagal copy sold as a original the quality of the disc could be the cause. If the player is very clean (no small hairs stuck to the glue that holds the lens in place) (never clean with a cotton swab, use a shammie swab with rubbing alcohol or isopropal 99%) the problem could also be that the lazer is just not strong enough and the whole lazer-motor assemble should be replaced. Older units could use 1 drop of light motor oil on the motor shaft at the bearing to help start the motor when the system kicks the disc to spin. If the player reads the disc at the time you manually spin the disc maybe a good cleaning and oiling is all that is needed. The disc spins clockwise. if the disk spins counter clockwise replace the whole assemble. Maybe simpler, just give the disc a good clockwise spin and quickly close the door and push play while the disc is still spinning. if it starts, there you go. Don't use caned air on the lazer assemble. it will blow the dirt further into the lazer mechanism under the lens and make matters worse! Good luck!!
Incorrect disc, err when disc is put in,
it is not recogonizing it
meaning you might have a blu-ray instead of a reg dvd
2helpful
Disc wont spin
There are 4 reasons a disc won't spin on the Slim PSP. The most common is a failed laser.
1. Failed laser -- the disc will not spin up to speed, or not spin at all, due to a bad laser. If you close the PS2 with no disc inside, the ps2 will never spin the disc. If you chose the PS2 with a disc inside but a bad laser, it still thinks no disc is inside and will not spin.
2. Lid closed sensors. There are two of them. One on the motherboard and one on the reset switch. These sensors let the PS2 know that the lid is closed. If one or both of these break, the disc will never spin because the PS2 will think the lid is still open.
3. Damaged case. If the case of the PS2 is damaged, the two parts of the lid that are supposed to press the lid-closed sensors will never press them.
For more information, pictures, and parts, click into the following page:
http://store.richspsxparts.com/slpsnospdi1a.html
Memorex dvd player 2040..disc won't stop spinning!
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
6helpful
5answers
Portable DVD player not spinning says no disc
Check to see if the disc is spinning. You can do this by one of two ways either
  • a:) Listen for the disc to spin after inserting it or
  • b:) Place disk in drive right way up (so that the label is not upside down). Load the disc and eject the disc again to se if the disc has moved i.e. the writing may now be upside down.
If the disc does not spin then it is likely that there is something wrong with the disc motor. If it does spin then the issue is more likely to be with the laser unit. Try cleaning the lens but if this doesn't help it's likely to be a more serious and ultimately more expensive problem.
Hope this helps
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
Alexander
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
