I need to replace a SAMSUNG CDRW/DVD SN-324F but cannot find any instructions on how to remove the old one. I suspect that it is a case of once having got the case apart it is obvious how it "should have been done", but by then the damage has been done!
Again, I suspect that the installation of the new part is the reverse of removal.
-   I have the same problem! My old internal DVD drive of the Samsung x05 is broken and I cant find the right screws to replace the drive. I'm happy for any information-   CyberSAD
Best Solution
posted on May 27, 2008
Guest
Rank: Apprentice
Rating: 0%, 0 votes
if anyone needs pics from a gateway arc200 i have taken all photos necessary to
get this pain in the *** drive out !
thake out the screws on the bottom of the lap top then there are 3 very small clips holding in the keyboardone at the control key one at the space bar and one at the down arrow key push thes back and lift out the keyboard it has a cable conector on it so be carefull then you will see two screws holding in the cd drive and a ribbon conector remove it by pushing forward the small ribbon holder then remove the drive
I have a Toshiba Satellite L305 laptop. My daugher stepped on the screen. There is just a straight...
(More)
I have a Toshiba Satellite L305 laptop. My daugher stepped on the screen. There is just a straight line from one side to the other. What can I do to fix this? I am a single mother and can't afford an expensive repair. Thank you so much for your time.
I have a Dell Inspiron 8200 with a Matshita CDRW/DVD UJDA740 and it has stopped burning cds. It now...
(More)
I have a Dell Inspiron 8200 with a Matshita CDRW/DVD UJDA740 and it has stopped burning cds. It now plays them and rips music from them but and WMP 11 it says 'Connect burner and restart program'. Can anyone help????
El problema que tengo es que cuando trato de conectarme a Internet, me sale un aviso de que no...
(More)
El problema que tengo es que cuando trato de conectarme a Internet, me sale un aviso de que no existe modem, siendo que está instalado, porque?
