Compaq Armada M300 Notebook Logo
Posted on Oct 29, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Faulty mouse the right click is not workin on my Compaq armada laptop. It was workin absolutely fine till recently. I recently installed the sky internet CD on it. well, the internet access cud not happen successfully, as a bonus, the right click stopped working. I even tried uninstalling the entire Sky broadband thing. But still of no use. Possibly some files important for running of the mouse might have got deleted. pls help.
Lyle Siemens
Level 2:
  • Expert 328 Answers
  • Posted on Oct 29, 2007
Lyle Siemens
Expert
Level 2:
Answers
328
Questions
Helped
208557
Points
976
You need to check your settings by going to Start-----Control Panel------Mouse. Make sure everything is normal. If its all good from there, try a different mouse. The software installation should have nothing to do with your mouse function.
Compaq Armada M 700 Owners Manual
The only thing I can think of is reduce the resolution on your screen to fill it. Go to start menu, click on control panel, click on display, go to settings, "top right" take your mouse and go to screen resolution put mouse on arrow and move one notch to the left click apply, a window will appear at the top asking if you want to save these changes click okay and you are done.
How will I know if my laptop Compaq Armada m700 is fully charged already?
Hi
You do not say which operating system you are using.
Right click on the toolbar at the bottom of the screen > properties > notification area > tick the Power under System Icons - Select Which Items to always show > Apply > OK > float the mouse on the battery icon to see % of charge and charge time remaining.
I hope this helps.
How to copy and paste by using laptop mouse?
click mouse at starting strect and cover area and then click on copy and then take it where you want to paste and click the mouse button.
YESTERDAY MY VOLUME WAS WORKING FINE, TODAY I CANT HEAR ANYTHING, CAN U HELP ??
click right mouse click harddware -divece manager look sound option (speaker sign} if not stall u can see yellow sign,install sound by using ur board cd. 2/ go run type control click sound andaudio option then u can get volum/sound/audio/voice/hardwer option check if incorrect correct it .3/ look ur speaker's volum is off or not? what u keep volum on mute or not? ..... thanks
1helpful
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Tryng to get a new 60 GB hardrive to work in my Compaq Armada
It Ended up being very simple. I simply found a Dynamic drive Overlay Software and all works fine
Display problems
Hi,Have you installed new RAM recently?if so it might not be properly seated,it's worth reseating it and see if that helps,or try removing RAM sticks alternately it may be a faulty one.
Crazy Mouse
The j-mouse switch is faulty or dirty. The best thing you could do to solve this is replace the keyboard on the laptop. The HP Parts Store should have replacement keyboards that you could order or search on eBay.
1helpful
2answers
Mouse
I had the same problem with my compaq armada e500. I've been using an external PS/2 mouse for over a year and just now fixed the built-in touchpad buttons. In the mouse settings applet in control panel there is a setting for click speed. In Win 2k there is a little jack-in-the-box test icon. I moved the click speed slider to the slowest setting and my mouse came back like magic. I've searched and found lots of people with this issue, I can't say this is the only solution, but it certainly was easy. Of course, first I downloaded all the original COMPAQ Armada e500 notebookPC touchpad software from http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=96717&prodTypeId=321957&prodSeriesId=96231&swLang=8&taskId=135&swEnvOID=181
BTW, I appreciate the workarounds offered by posters here and on other tech support sites, but when someone wants to fix something, it doesn't help to say, "Oh, just give it up and spend money to get around the problem."
If you are still out there, dave, Instead of a USB hub, may I suggest (if you have the resources) picking up a PCMCIA card with at least two more USB ports? They are less than $100 and it really saved my neck when my onboard USB died. Don't be offended, but just in case you haven't noticed you have them, the slots are on the right side of your E500, just to the left of the headset and mic ports. The e500 has two slots and the cards come in different sizes for different laptops, but ours is (luckily) pretty standard. I bought my card at BestBuy.
2answers
Compaq armada m700 mouse is very irratic
did you try replacing the mouse? Or installed the mouse driver.
Top Compaq Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
