Whirlpool 24 in. GU1500XTLS Stainless Steel Built-in Dishwasher Logo
Posted on Jun 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Water in bottom of dishwasher; seems to be spraying up during cycle; doesn't seem to be a pump if spraying up? what else could cause the water not to drain?
Anonymous
Level 2:
  • Expert 149 Answers
  • Posted on Jun 12, 2009
Anonymous
Expert
Level 2:
Answers
149
Questions
0
Helped
57651
Points
438
Does it have a separate drain pump? when you look under it, is the drain line connected at front right corner of pump housing?there is a check housing in the tube that the drain hose connects to. it unscrews and has narrow opening on threaded end..may be blocked there.
Frigidaire FFBD2403LW normal cycle hum
Hello ddux97 - Often this occurs because either not enough water is being pumped to the spray arm or in other words the full flow of water is not making it to the upper spray arm. Will the spray arm rotate freely? If it does not, then you might have to remove or replace the spray arm assemblies since it is possibly damaged. Confirm that the drain hose is strapped up properly under the sink to prevent the water from siphoning out during the cycle. If issue persists, I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully.
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 • Dishwashers
1helpful
My mother-in-law called and her dishwasher is making a loud noise when the motor runs. sounds like a bad bearing somewhere? the noise stops when it drains (motor not running?). does that sound like the...
There is only one motor -- it runs a water pump for recirculating the water when it's washing and runs a water pump when it's draining.
It sounds like the spray arm is making the noise -- this is the part thru which the motor / pump forces the water during the wash cycle -- the pumped water causes the arm to rotate -- a warn or loose spray arm or mount is likely the problem.
Or, it could be just some utensil stuck in the bottom of the dishwasher which the spray arm is rubbing.
More info, let me know.
Charlie
Hi, I have an LG LDS4821 dishwasher and it appears to stop working properly. The dishes don't seem to be cleaned at all. It seems like the spray arms are not spraying the dishes as the dishes are still...
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher
Spray Arms not Spinning
How to Buy
Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The
Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
4helpful
3answers
The dishwasher seems to be cycling - but I no longer get the flush into my disposal and I don't hear much water circulating inside the machine. Also, the soap doesn't all diappear. Any suggestions?
The high pressure water pump is defective and is not spraying the much required jets of water to the dishes.
This is the reason that your dishes are also not cleaned.
You might have to remove and check if the pump is faulty or a cleaning job can rectify the issue.
Both spray arms of my DU943PWKQ0 do not turn or spray. The motor is moving and the it drains without problem. During the wash and rinse cycle I can hear the sound of water, however it doesn't clean at...
Try rotating the spray arms by hand. It should rotate freely. If possible clean the arm rotating place by removing them.
Arms rotate by by pump pressure only. finally check the water pump also.
2helpful
2answers
Wash cycle doesn't seem to work. bottom has water
Your gonna have to pull the dishwasher out and shut off the water line. Then disconnect the water hose and get you a bucket. Then turn on the water line to see if water comes out. If water comes out strong then your water supply line is good, which means your inlet port on the dishwasher is clogged or hard water has clogged the little holes in the dishwasher arms. Dishwashers are meant to leave a little water remaining at the bottom to keep the sensor from burning up.
Feb 16, 2010 • Dishwashers
Our dishwasher is not running through all cylcles
Either:
1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Dishwasher
Can't really supply a solution, mine has done this since Christmas. Mine seems to be related to the volume of water taken(or indeed not) into the machine. I have resorted to chucking a bowl of water into the bottom at the start (after the initial draining cycle) of the programme and during the rinse. Not exactly automatic & I can't imagine it will do the pump much good flogging it without a sufficient prime, however it works for me. I'll keep an eye to see if a more substantive fix comes along. Best wishes.
Jan 11, 2008 • Dishwashers
2helpful
2answers
Dishwasher not spraying
It could be a motor or a pump issue. The dishwasher has a motor that attached to a pump which forces the water up into the sprayer arms and during the drain cycle, it pushes the water out of the dishwasher. The motor (and pump) located beneath the dishwasher. Good luck!
Sep 12, 2007 • Dishwashers
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
