Question about Toshiba 46HM95 46" HDTV
Red/Green Light Problem
Bulb blew and replaced it.  Turned on TV but no picture, the red light comes on and then is followed be the green light that blinks about 15 times before the TV turns off then back on, repeating the process.
Re: Red/Green Light Problem
Had same problem after only 3 months, tech looked at it said had a power circuit problem causing it to keep cycling, they exchanged my TV. No problem since.
Posted on Nov 30, 2007
0 characters
3 Points
I have a panasonic pt-56lcx16 and it needed the bulb replaced, i got a new one and installed it. I turned on the power button on the tv, then it makes a electricity sound where the bulb is but doesnt come...
If the electricity sound was loud and static sounding then you had a short with arcing which is not good and you blew a board or the socket that the bulb went into. Check that there is current at the bulb fitting.
Mar 02, 2014 | Projection Televisions
TV won't stay on
One of two things can be the the bulb is bad...two the ballast is bad. If the bulb is not bad then the ballast can usually be fixed by replacing a resistor on the board is labeled R3 and is a 1000 ohm resistor
Jul 25, 2010 | Toshiba TheaterWide 46HM84 46" Rear...
If you still have red light , it means the temperature of the lamp is too much. Did you buy the original part number of the lamp.
Jul 24, 2009 | Projection Televisions
Have problems with mitsu wd-52327
check the current maybe high voltage occur or due to loose connection high amper occur.
Jun 04, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Picture went green. how do i change bulb??
you can get the red replacement CRT at the following link and they provide free instructions. Heres the link to the correct red for your model.
Apr 20, 2009 | Philips 55PP9701 55" Rear Projection...
TV won't come on- green and red lights flashing
It may be your bulb.  We just had to replace ours after 4yrs.
Dec 31, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
No picture but normal sound.
projection bulb needs replacement
Aug 11, 2008 | Projection Televisions
Toshiba 46HM95 46" HDTV Logo
191 people viewed this question
Top Toshiba Projection Televisions Experts
Jaime Hernandez
Dave Naylor
Dave Naylor
Are you a Toshiba Projection Television Expert? Answer questions, earn points and help others
