Question about Apple iBook G3 Mac Notebook
G3 time issue
Time is off and want to know how to set time correctly
    Novelist:
    Champion:
  • 382 Answers
G3 time issue - 6d7cb5a.png IF YOURE running tiger, go to the apple top left screen, drop down menu, choose SYSTEM PREFS....it should look like..... 3rd item on 4th row......you can select it manually or let it set by netowrk if you have access to the internet at the time. Now if your date and time keep setting back when you restart your computer, you may need to zap the PRAM (****-ram). Also if your battery is not reliable or not keeping a proper charge, that will affect your machines time and date.....try checking your battery's cycle....... www.coconutbattery.com
Posted on Nov 02, 2007
SOURCE:
How do i set the correct time on my tablet
Can you try running the installation wizard again?
Dec 01, 2015 | Archos ARNOVA 9 G3 4GB 9.7" Capacitive...
How to disable ECM and Reduce Baud rate for Canon MF4270 G3 Fax ?
Your approach is correct however it doesn't look like the MF4270 provides for these settings. One might expect to be able to select G3 or ECM or set a lower TX speed.
I located the settings for different Canon Fax machines here:
VoIP Fax Settings
Jul 25, 2014 | Canon imageCLASS MF4270 All-In-One Laser...
How to disable daylight saving time on iBook g3???
preferences. date and time.
can also go to the time icon and click it to open settings. select or deselect the dst option.
Apr 07, 2014 | Apple iBook G3 Clamshell (M2453B) Mac...
When I send a fax the date is wrong. how do I fix that?
set date and time in ur machine correctly. it is in user settings
Jul 06, 2009 | Canon Office Equipment & Supplies
How to set the date and time
Below are instructions for changing the Date and Time for your machine. At the end, you will find a link for the owners manual for the 2060. Best of luck.
Greg
Entering the Date and Time
Follow these steps to enter the date and time.
1. Open One-Touch Speed Dial panel.
2. Press Data Registration.
3. Press Set twice.
4. Press Set again, then use the numeric buttons to type in the correct
date and time.
Use the MM/DD/YY format for the date and use the 24-hour
clock for the time, so 2:30 p.m. would be 14:30, for example.
5. Press Set to save the date and time.
6. Press Stop to return to standby mode.
http://aaabusinesssystems.com/pdf/_2060_Users_Guide.pdf
May 29, 2009 | Canon LaserClass 2060 Fax
Monitor does not come on at reboot.
this iz due to some loose connection of ur cables.
try 2 figure it
Apr 25, 2009 | PowerLogix PowerForce G3 ZIF, 1.0 GHz...
Canon Fax G3 How do you set the date and time?
Lifted up the side panels and found the correct button to set the date and time.
Thanks!
Jan 05, 2009 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
I Have a Cannon, Laser Class 710, Super G3 Fax Machine and need to know the procedures to reset the time and date. Can't find my manual.
lift up the 3 speed dial panels
use Data registration key
select date/time settings
use the 4 direction arrows to navigate thru menus
and after changing info use set key to lock in setting
let me know if ya need more help
these are great faxes
May 23, 2008 | Canon Office Equipment & Supplies
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Canon G3 irresponsive Shutter & non-see through viewfinder
optical view finder. this seams odd as it is only a lens. Was the camera dropped at some point? that may explain both issues. if not then I need to know a little more prior to offering an opinion.
Jul 08, 2007 | Canon PowerShot G3 Digital Camera
Apple iBook G3 Mac Notebook Logo
75 people viewed this question
Top Apple Computers & Internet Experts
marty morrison
marty morrison
Paul Carew
tylerbell49
Level 1 Expert
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
