Question about Freezers
Amana upright frost free freezer, early 1970's vintage
Freezer case has line voltage  (120 volts) in the case (box) .  The ground plug has been isolated with a 2 prong connecter.  Freezer runs in this  mode, other wise there is a "dead short to ground".  Is is likely the defrost heaters are shorted to case? or compressor has internal short?  My last test showed no short to ground (case) when compressor running but 120 volts in case when compressor off, pressumably when in drefrost cycle. The defrost timer was removed from contact with the case.  However previous test with every thing in place had 120 volts in the case when compressor was running and none  when compressor off----HUH?
  • 363 Answers
For the love of God get rid of this death trap.
It could be that it was meant to have a neutral earth, ie the neutral is connected to earth at the substation and house inlet and somehow the live and neutral has become reversed at the plug.
You have seen the case becomes live, this may be happening due to leakage current or a short as you say.
Either way the earth was there for a reason, to stop the case from becoming dangerous and you have removed that protection.
Neither the heater element or motor windings should have continuity to the case, I'd disconnect and check these out individually to isolate the problem and repair it, then put the earth connection back before using the freezer.
Posted on Oct 29, 2007
Frost builts up in the coils
Frost will normally build up if you do not have frost free freezer and in which case it is possible the frost free system is faulty. If it is not frost free then it has to be defrosted a few times in a month. However if the frost comes up very quickly then there are possible causes.
You may be having leakage from the door seals or there are items in the freezer that are not properly covered to avoid moisture escaping. Other possibility is that your freezer is set too cold and there are not many items in it.
Aug 18, 2014 | Amana Freezers
Model 253.28432807. Household power went off today for a couple of hours. Restored. Freezer has power but display is illegible. Up arrow does nothing. Down arrow changes display but display is erratic and...
Electronic components are very sensitive to voltage surges, spikes or sags.
Voltage is not delivered at a constant 120 volts. With alternating current, the voltage rises and falls in a predetermined rhythm. The voltage oscillates from 0 to a peak voltage of 169 volts. Most appliances and electronics used in the United States are designed to be powered by this form of generated electricity.
During a power surge, the voltage exceeds the peak voltage of 169 volts.
A spike in voltage can be harmful to appliances and electrical devices in your home. An increase in voltage above an appliance's normal operating voltage can cause an arc of electrical current within the appliance. The heat generated in the arc causes damage to the electronic circuit boards and other electrical components.
(Smaller, repeated power surges may slowly damage your electronic equipment, over time too.)
Voltage sags, a.k.a voltage dips or brownouts, is another form of electrical disturbance that can damage appliances as well.
The bottom line, power surges, spikes, and sags can vary in duration and magnitude; and can damage electrical equipment ranging from stereos to computers to any household appliance that uses chip board circuitry sensitive enough to "blow" due to over or under-energizing it.
Jul 03, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Ice building up on bottom of frost free upright freezer
You have a plugged defrost drain line.Lokk on the very bottom and way way back to see if yu can see the drain. Also check underneath you lmay be able to get to it from there or else in back of freezer.Hope this helped.
Jun 26, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
I moved my upright freezer so I unplugged it , moved it and plugged it back in and it stopped working. I left it unplugged overnight, plugged it back in, same result. Any suggestions?
Maybe it is in the middle of a 21 minute defrost cycle? Is the fan running? Sometimes the defrost timer gets hung in defrost. If that is fine I would see if 120 volts is getting to the relay on the compressor. Sometimes an older temp control will die if fiddled with. Did you turn it before moving the freezer? Those are some things I would check. Sometimes wires get yanked out of place when you move an appliance so check that as well. Post your model number and I might have a service manual you can download OR just go to my website and find one HERE
Dec 10, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Kenmore upright freezer quits working but can restart when the unit is unplugged and plugged back.
check the freezer back wall @ bottom if frosted up 1-bad heater (a-glass tube heater or cow rod. 2-bad times 3-bad defrost senor 4- bad fan motor
Aug 15, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
My amana upright gets cool but not cold enough to freeze probably not even as cold as a fidge. the problem started when we moved and stored it out in a shop that was partially heated. since then we have...
Good day,
Somewhat handicapped not knowing if it's a conventional freezer or frost free.
1. If it's frost free check to see if the fan motor is running in the freezer compartment.
2. As well if it has a fan motor in the compressor compartment, see if it is running as well.
3. If it is a conventional model, make sure it is turned on and make sure it is running. If running, then it has lost it's refrigerant charge or the compressor has lost it's pumping capacity.
4. If it is item 3, then unless it's less then 5 years old, the sealed
system/compressor problem is so pricey that it's not a practical repair. If under 5 years Amana will pay for these repairs, whether it's conventional or frost free.
Nov 04, 2009 | Amana 15.0 cu. ft. / 425 liter Upright...
I have a frigidaire freezer upright model#ffu20f9gw3
Without any additional info, there are a lot of possibilities:
1. Condenser coil (underneath unit) is dirty and clogged.
2. Compressor is failing. (need A/C tech)
3. Metering device is clogged. (need A/C tech)
4. Refrigerant charge is low. (need A/C tech)
5. Door seal is broken (frost will form around door).
6. Defrost heaters are stuck on (replace defrost timer located underneath unit at front).
7. Condenser fan has failed (underneath freezer on back).
8. Evaporator fan (inside fan) has failed (ice will form on cooling coil).
This should get you started...
If this helps you, please select YES to the first two ratings questions. Thank you, and Good Luck.
Oct 13, 2009 | Frigidaire Freezer 20.3 Cu. Ft. Frost Free...
Kenmore freezer quit working after power outage
simple stuff, you have a compressor a stat and power. check the receptacle to be sure you have 120 volts . then check the compressor with stat at max cold setting to see if you have 120 volts at compressor. if you do then compresssor is bad =new compressor or new unit. if no power to compressor then stat is bad= new stat. i always recomend new unit cause new stat or compressor wont fix a freon leak.... i have replaced a few compressors that died soon after due to a freon leak. good luck...
Nov 23, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer frost
An upright freezer that is not frost free will have the coils in the shelves (shelves are non-removeable) and that is where the frost will buildup.  If your model is like this then it will have to be defrosted periodically.  If your not sure then give me the entire model # from the sticker inside the freezer and I will look it up for you.
Oct 16, 2007 | Amana 19.7 cu. ft. / 558 liter Upright...
Freezers Logo
135 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
