Question about Sony KP-51HW40 51" Rear Projection Television
Color picture there is only a green and blue showing highlight on the screen
    Scholar:
  • 137 Answers
Check and replace your component cable wire (Red,Green,Blue). This is a very common problem with these component cables
Best regards
circuitcity
Posted on Dec 11, 2007
After lamp replacement, why is picture still green?
it seems like the green was not defective before you replaced the green. remove the red =no change in the screen color, that could be bad. put back red, then remove blue=screen color changed, blue is good, hope you got the idea.
Oct 08, 2015 | Sony Televison & Video
When texting someone what does it mean when it's delivered to the IPod and stays green
The color of the text indicates what device/service they use to receive the message. Blue means they are using iMessage on an Apple product to receive the message. Green means it is standard SMS on a non-Apple device. Gray is the default color for messages received from another user.
Only "blue" messages show receipt of delivery and if they have been read. Unless it says the message is not going through, it is.
Jul 24, 2014 | Apple iPod touch
Green picture
Hi Lizzette,
I am afraid your problem is a little technical. Well if you know something about lcd tv technicals, the problem seems to be the T Con board and/or its connectors. Check the ribbon cables and connectors, clean them properly and and start the tv.If it is not possible or it does not work, please consult someone qualified to handle your set. Good luck.
Dec 18, 2013 | Samsung 46 in. LCD HDTV
Pioneer bdp 51fd picture color is green
check screen options. sometimes you can change the primary color's intensities(it looks stupid at 100% for all). You might have red a little low making yellow and blue show up greenish on the screen.
Oct 28, 2012 | Pioneer Televison & Video
LG Projection TV Model# RT-49NA11T Green color gun shows bent arc on top & bottom.Red & blue guns are ok.How to adjust the green gun to remove the bent arc. This is causing picture shows mix...
This problems ur tv have can't not be fix by adjustment.The tv have a problems known as convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board,must be replaced to repair the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Jan 10, 2011 | Panasonic PT-53WX53 53" Rear Projection...
How do you know if you need to replace the fluid? can you show me some pics of good red green blue color or some bad colors
If the glycol is bad, there is a easy way to tell:
Remove the back cover and with the set on use a small mirror--put it over each of the three Lens--red will never be bad this way.
What you want to see is a green picture on the green tube and a blue picture on the blue tube.
If instead of a picture either the green or blue look like a floodlight with no picture--the glycol is contaminated.
What happens is bacteria grows in the blue or green glycol--never the red--for some reason it does not like the red color.
Usually the blue will be the one first affected---picture will have a yellowish look over most or all of the screen (turn the color all the way down and stand back at least 10 feet and look at it,
Changing Glycol involves some important things---this stuff is like antifreeze bit ten times more toxic.
If you find yellow and want to know what is really involved respond to this posting and I will assist you.
If this information told you something you did not know, rate this solution as I do this here for free.
SD TECH
Aug 16, 2010 | Philips Magnavox 9P6034C 60" Rear...
My Sony KP-46WT500 screen shows the tv image in blue only for a few seconds, then it goes completely blank (as if it were off). Do I need to replace the bulbs?
It is rear projection TV that use 3 picture tubes of red-green-blue to show color picture on tv front screen.
Do you see standby red light blinking when TV shuts off after showing blue image for a while?
If red standby light is blinking, please count it how many times it blinks, there would be 3 seconds pause between blinks so count pause to pause and post it here to find out possible solution.
Thanks.
Dec 22, 2009 | Sony KP-46WT500 46" Rear Projection...
SONY TV MODEL # KP-65WV700 SER.# 9002706
Blue Gun is right side of TV if you look in TV from back side. Part number is as follows..
8-733-663-25 {CRT 07MVC62(B)-L} [KP-65WV700 ONLY]
Mar 13, 2009 | Sony Televison & Video
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Mitsubish hd 1080I wt 46809
Check settings first to make sure no one changed anything out of the ordinary. Are the shadows that of a color or darkened shadow? It could be out of convergence, which can be corrected in the menu - or it could be low quality video cables to. Also, if there is no green, does a white color show up when you're in a menu mode (Red+Blue+Green = White Image)? If so, then the green picture tube is working and it's just a color adjustment, otherwise you may have to invest in a new green picture tube.
Apr 22, 2008 | Televison & Video
Sony KP-51HW40 51" Rear Projection Television Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
