Question about Yamata FY101-1A
It the same problem, needle does not move up and down
I followed the instruction like this to operate the machine. - Press the foot paddle gently and turn the wheel towards you whitout turning the switch on so as to release the brake of the machine of the first start. I have tried like this several times, eventhough we took a risk by turning the power on but the needle still does not move. We could hear the noise andthe smell from the motor ,then we had to stop to do so. Please give me advice and thank you for your help.
  • 327 Answers
Re: It the same problem, needle does not move up and down
The motor is defective. If it's used or older, cleaning the motor with compressed air or vacuum might work if its very dusty.
Posted on Oct 29, 2007
0 characters
3 Points
My sewing machine model is B 750 QE. Always starting to sew the lower thread keeps knotting up it drags down the fabric and the cogs come on the screen..So I looked at the instructions and followed the...
1. To solve your knotting problem. Learn to always trap or grasp your thread ends for the first few stitches.
2. When the dogs are down, sometimes you have to grasp and jiggle or turn the hand wheel while re-engaging the feed dogs.
3. It sounds to me as if you aren't making sure that the take up leaver is in the top position before you press the "foot button down" Make sure you press "needle up" before you press foot down. That way the dogs should be in the correct position for you to get the fabric under there and proceed. In the mean time... I would strongly recommend you go back to your dealer and take some lessons. It sounds to me that when you learned to sew... you were not trained the proper procedures.
Oct 01, 2013 | Bernina Sewing Machines
I need a manual for a singer touch and sew machine. It,s pretty old so i gope you can help me. I don,t know how to wind the bobbin. Help!!
Unlikely you will get a manual but here are the instructions.
Presser foot up, thread the top of the machine as normal all the way and through the needle, open slide plate, push the little button to the side and the winder will raise, take the thread from the needle and wind it round a few times round the screw that holds the presser foot on, gently press on the foot control and the needle will go up and down winding the bobbin, when you have enough thread on the bobbin close the slide plate and you will hear the winder drop down, pull the thread to the back of the machine and you are ready to sew
Sep 14, 2013 | Sewing Machines
On brother vx 1500 when press foot needle will not move
It's jammed, take off the face plates and completely unthread it. Take out all the jammed up thread and it should operate freely:) hope this helped
Sep 20, 2012 | Sewing Machines
Why isn't my husqvarna foot press not connecting giving power for my needle to move. Machine does have power but does not run when pressing foot press.
have you checked to make sure the foot pedal is connected correctly to the machine?
if the foot pedal is connected correctly, then the machine needs to be checked to see why it's not responding
Mar 27, 2012 | Sewing Machines
How to set up
  • Remove your Janome sewing machine from the box, placing the main machine on a hard surface appropriate for sewing and the accessories and smaller items to the side. Unwrap all of the wrapped items. Remove the tape used to protect the machine during shipment. Set aside the power cord and foot pedal.
  • 2
    Attach the power cord to the machine. The power cord plug-in area is located on the lower right side of all Janome sewing machines and has a series of metal prongs and a power switch. Fit the female end of the power cord onto the metal prongs and push it gently until it no longer moves.
  • 3
    Attach the foot pedal to the machine. The foot pedal plug-in is also located on the lower right side of all Janome machines, right next to the power cord plug-in. Press the foot pedal plug-in into place gently until it no longer moves.
  • 4
    Turn the power switch on. The power switch is located in the same area as the foot pedal and power cord plug-ins and is a rectangular black switch. Press this button. The sewing machine light will turn on.
  • 5
    Place a spool of thread on the spool pin, located on the upper right top side of the sewing machine. Place the thread so that the thread unwinds in a counterclockwise motion, with the thread coming off the back of the spool.
  • 6
    Insert a needle into your machine. Consult your owner's manual for the appropriate size and type of needle. Turn the needle clamp screw, located above the needle area, toward you to loosen it. Turn the needle so that the flat part of the upper shaft area faces the rear and slide the shaft of the needle up and into the needle area. Turn the needle clamp screw away from you to tighten the needle and lock it into place.
  • 7
    Wind the bobbin and insert the bobbin into the bobbin case. This procedure may vary depending on the model of your Janome machine, so consult your owner's manual for specific instructions.
  • 8
    Thread your machine according to the directions in your owner's manual. Like the bobbin, this procedure can vary widely depending on the model of your Janome machine.
  • 9
    Set your tension, located on the front of the machine, to halfway between three and four. The tension may be a dial or it may be computerized and located on the LCD screen, depending on your model. Consult your owner's manual to find out how to set the tension.
  • 10
    Place a piece of scrap fabric in the machine and sew a test seam before you start to work on a project to make sure all of your settings are correct.
    Things You'll Need
    • Janome sewing machine
    • Owner's manual
    • Needles
    • Thread
    • Bobbin
Jan 11, 2012 | Janome Sewing Machines
I have a singer 6106 but no manual. When I press the foot the needle doesn't move although the outer wheel on the right hand side of the machine goes round. If I move the inner wheel on the right the...
go to and type in your model number, then click "search" to locate the manual for this machine.
Sounds like the clutch is disengaged on your flywheel. Hold the outside of it and turn the inside bit away from you to reengage it.
May 28, 2011 | Sewing Machines
Beginner on a sewing machine just got a Euro- Pro from my aunt having a hard time getting it to sew something. I threaded it and ready to go now it wont sew soooo what might be wrong with it?
See if you can find your model here and refer to the instructions to see if you missed something when you threaded the machine -
Always thread a sewing machine with the presser foot up so the thread enters the tension so it will properly work when the foot is down for sewing.
Check the needle to be sure it is inserted correctly - this is usually with the flat side facing the back of the machine.
Hold onto the thread tail at the needle and handwalk the needle down and back up, which will bring up the bobbin thread.
Hold onto both threads and pull them under the presser foot and to the back of the machine.
Place the fabric under the presser foot. Lower the foot and move the needle down into the fabric - press the foot pedal.
Feb 28, 2010 | Euro-Pro Sewing Machines
Needle keeps catching the embroidery foot and breaking
Happened to me to All I did was to press the embroidary foot a little backwards and check if the little arm that rest on the shaft that goes up and down is seating correclty.
Mar 20, 2009 | Singer CE-200 Quantum Futura Computerized...
Needle won't move on Bernina 930
If the machines motor is running but the needle isn't going up and down then the baste stitch finger is gummed up and needs to be serviced.  This is a simple fix and it happens all the time on those machines.  Take it to your local Bernina dealer for a standard service.  Also if you really need it in a pinch try pushing up on the needle bar that sometimes will fix the problem but it will still need serviced.
Sep 16, 2007 | Sewing Machines
Sewing Machines Logo
61 people viewed this question
Top Yamata Sewing Machines Experts
Bargain Box
Bargain Box
isaac johny
isaac johny
Michael Thomas
Michael Thomas
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
