Question about Kodak EasyShare DX6490 Digital Camera
Lens barrell doesn't retract for zooming out, only for shutting off.
When off, the lens barrell is in the fully retracted position.  In any swithch on position, the barrell fully extends and stays that way until shut off.  The zoom control works for digital zoom, but doesn't move the barrell.  There is noise like a motor is trying to move the barrell.  It seems to focus okay.
    Genius:
  • Kodak Master
  • 1,019 Answers
Hello, Sounds like you have a drive motor/gear assembly malfunction,this type of failure is costly to repair.
Best Regards, Russell
Posted on Jan 23, 2013
  • 11967 Answers
SOURCE: my zoom lens just wont retract.
Fixing a Lens Error on a Digital Camera This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Oct 21, 2009
  • 3 Answers
SOURCE: lens jammed will not retract,
I have had the same issue were the lens would not retract. took it in for extended warranty work. lens now retracts but takes lousy pictures.
When I purchased this camera family members ran out and bought thiers shortly after I did. One by one the same issue has happend to their v1253's.
I dissmantled one and found that there is a tiny battery on the power board inside of the camera. apparently the tiny battery's life is about 1 1/2 years. This battery is not serviceable as it is welded in place. I am not one hundred percent sure if this is the cause but it makes sense.
It would be nice if kodak would own up to this issue and make good on repairs as they did with my kodak 5500 all-in-one printer and it's crappy print head. Kodak has sent me 4 print heads in the 2 years I have owned it.
I have 5 of the v1253's in my family and every one of the are dead. I would think a $250 product should last longer than 1 1/2 years.
hope this helps.
Posted on Dec 01, 2009
  • 11967 Answers
SOURCE: My camera zoom will not retract and the camera
Posted on May 01, 2010
  • 11967 Answers
SOURCE: The lens does not retract after zoom, and the the
Posted on Jun 04, 2010
lock123
  • 6831 Answers
SOURCE: My camera is displaying error code 411, 1, 1, 107
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 27, 2010
When using the zoom control, why does the lens zoom out but will not zoom back in with the zoom control?
hi,
your camera's zoom is faulty, there is some sensors with which controls the lens retraction, if the lens's position is wrong the sensor cutting edge will not get in the proper position.
open the camera, take out the lens, open it carefully, if the position of the lens is not in proper position, you can see some marks on the lens barrel fix it in the correct position.
Feb 25, 2016 | Nikon COOLPIX Cameras
THE ZOOM WHEN USED GOES OUT AND THEN RETURNS AUTOMATICALLY TO NORMAL
Could it be you mean the lens barrel comes out, but I can't use the camera? Or does the lens barrel directly go back to the "in" position. If so, check the battery, or even better charge the battery. Then check if the lens, on its way out, is not blocked by anything. Because the slightest obstruction, will cause the lens to retract. The camera does this to avoid extra damage to the barrel and or the mechanics behind it.
May 25, 2014 | Ricoh Caplio R6 Digital Camera
Lumix tz30 lens will not retract
the oven will not igniter it get power so it not the breakerso can anyboby tell me whats going on?
Jan 18, 2014 | Panasonic Lumix DMC-TZ30 Digital Camera -...
I have a Nikon AF-S 55-200mm 1:4-56ED. Focuses fine, lens goes in and out fine...except...it doesn't retract completely flush with the barrel of the lens. Is this a big problem?
I do not have that particular lens in my collection, but not all lenses do completely retract to a flush position. If your lens performs well at all focal lengths and takes sharp pictures, it is probably ok.
Aug 26, 2012 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
Zoom lens won't retract on fujifilm f410
This indicate that there will be some problem with your camera Lens. Try to follow these steps to resolve the issue:-
1) Switch the camera OFF and then ON again. (May be your camera lens is struggling to extend)
2) Load new or fully charged batteries.
Else your device need service (repair)
Rating the solution is highly appreciated....Good Luck
Mar 03, 2010 | Fuji FinePix F410 Digital Camera
My dsc hsx-1 zoom lens wont retract from max.
my cam z sony DSC HX1..the problem z when i zoom in(max) the objct i m zoomin doesnt get focusd....when i shoot it the pic z totally blurrd....no matter how mch i try 2 focus with the manual focus option the outcum z da same....
Nov 27, 2009 | Sony Cyber-shot DSC-HX1 Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
Olympus 8080 C 8080 wide zoom
It may have jumped a tooth, something like a car timing chain. The Zoom in this camera is a barrel that has 3 cams that rides inside another barrel that has "tracks" for the cams. The motor rotates the the outer barrel via gear teeth, forcing the inner barrel to extend or retract. There is a tab on the gear teeth that might index the position of the zoom lens. If this tab is in the wrong position, if the gear jumped a few teeth, the camera may not know where the zoom lens is in relation to the inner focusing lens, and cause the "zoom error" If that is the case, I can help you get it back into position. This is a theory, but does explain the tab on the gear and the constant zooming.
May 27, 2008 | Olympus Camedia C-8080 Wide Zoom Digital...
Zoom lens won't fully retract
This is a gradual breakdown of the zoom mechanism due to ingress of dirt or having had a knock. A repair will be expensive- Fuji support will advice.
Sep 27, 2007 | Canon PowerShot S1 IS Digital Camera
Kodak EasyShare DX6490 Digital Camera Logo
57 people viewed this question
Top Kodak Cameras Experts
Jerry Greenberg
Jerry Greenberg
Computer Links
Are you a Kodak Camera Expert? Answer questions, earn points and help others
