Question about Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB (DELLP3667) PC Desktop
Networking I was wondering if i use a Ethernet crossover cable to connect two computers. What will i be able to access and is it dangerous with the Internet on one of the computers?
  • jatman1271 Nov 12, 2007
    My friends pc does not turn on, and he cannot check inside because he cannot open his pc case. What shall he do?
  • 84 Answers
You will be able to access the other computer and visa versa if you have the computers set to share everything which I would not. Also if you are using a wireless router there are security settings for it that can help you be secure with your network. And yes if you do not have the computers secured it would be unwise to have that setup.
Hopes this helps you
Posted on Oct 29, 2007
Which type of cat-5 cable do i use to connect a cnet switch to a d-link switch
interConnecting two switches will need a crossover cable. Please use a crossover cable.
Oct 27, 2010 | Cnet CSH-800 8-Port Ethernet Switch
How can I connect my ps3 to my computer modem?
Here is a general guide I wrote. For Vista, however, I think you will have to go to the sharing tab instead of the advanced tab when you are browsing the properties of a connection...
1. Get a CAT5 or CAT6 crossover cable. The cable that came with the PS3 is a normal Ethernet cable, therefore it cannot be used for this operation.
2. Make sure you have two sources for network communication. For example, you can have 2 ethernet ports on your computer, or you can have a wireless card and a Ethernet port etc. It helps to draw out a connection blueprint such as this:
DSL Modem > CAT5 cable > Network Card 1 > Computer > Network Card 2 > CAT5 Crossover cable > PS3
3. Connect your computer to the modem and verify that you have an Internet connection. Then, click on Start, go to settings, control panel. Double click on Network Connections, and identify the connection to your modem (Network card 1).
4. Right click on the modem connection, and choose properties. Next, click on the advanced tab (Sharing tab for Vista users), and check the “allow other users to connect…” checkbox. After the checkbox is checked, click on the “Home networking connection” drop down box and select the name of the second network connection. Click OK and exit the properties window.
5. Finally, connect the CAT5 crossover cable from the second network adapter of the computer to the PS3, and voila, your Internet connection is now routed to your PS3. Please be aware that your computer must be on in order for your PS3 to stay online. In the long run, a router may be a much better device to use than your computer, since it consumes only a fraction of the electricity than your computer does.
Mar 16, 2010 | Sony Playstation 3 (PS3) Console
Hello Dear, I have 2 D-Link 10/100 Fast Ethernet Switches and 1 Broadband Connection (which requires Username & Password) and want to simple networking in my office lab i.e. pc to pc networking not...
my dear, you a router in order for you to connect or use your simple network . . you don't crossover cable in that particular situation . . here's the connection . .
1. from WAN to router - you already have that i know
2. from router to switch - use straighthrough cable
3. from switch to pc's - again straight cables . .
i hope this will help . .
Jan 14, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Connect D-Link DWL-G700AP to dreambox decoder
you can connect to your box via FTP via a crossover cable. If you can’t, you might want to read up on that before attempting this.
Now, what we’ll need is…
Ethernet cable (crossover or patch)
We’ll also assume that you have a router (wireless or not) and that your modem is connected to the ‘Internet’ or ‘WAN’ port.
If you have a free port on your wireless router, you can connect your dreambox to this. Use the ethernet cable (crossover or patch, most modern routers will accept either) connect one end to your dreambox and one end to a free port on your router. You don’t need to change any settings on your router or PC.
Over to the dreambox. Navigate to the networking page on your dreambox.
Setup -> Expert Setup -> Communication Setup
Dec 09, 2009 | D-Link DWL-G700AP (S2984376) 802.11g/b...
I get no sync between my network card and the
Make sure your not using a crossover through cable. Also make sure your not connecting the cable into the internet port, which is usually the first or last port.
  • A straight-thru cable has identical ends.
  • A crossover cable has different ends.
  • A straight-thru is used as a patch cord in Ethernet connections.
  • A crossover is used to connect two Ethernet devices without a hub or for connecting two hubs.
  • A crossover has one end with the Orange set of wires switched with the Green set.
Nov 30, 2009 | Belkin F5D5131-8 Ethernet Switch 8 x...
Cannot get the ethernet to work
The "cable unplugged" error points to an electromechanical problem. Something is broken.
The first thing to try would be to replace the ethernet cable (make sure it is wired straight through, since some hardware won't automatically configure for a crossover cable). If that doesn't work, test that the hub you are connecting to works by hooking it up at a friend's house. If the hub and cable are alright, it's possible that the jack on your network card is faulty.
Feb 01, 2009 | Linksys Instant Networking Hub
Networking 2 computers
Yes you can make a simple Network between 2 PCs ....but need what is called a "crossover ethernet cable" or "xover". A standard RJ45 ethernet cable WILL NOT work.
You also need to make sure both Pcs are in the same Workgroup and have unique computer names.... as is standard in Networking.
Dec 31, 2008 | HP Pavillion ZV6000 Notebook
Connect two computers together
Technically, yes. Both computers should have an Ethernet port (LAN), a crossover networking cable, peer to peer networking using static IP add, and Internet Connection Sharing on the PC with the Wireless Internet Connection. If by chance the PC with the Internet access is already using its Ethernet port, a second NIC could be installed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | Computers & Internet
Dell OPTIPLEX GX1 PIII-667MHz 128MB 10GB (DELLP3667) PC Desktop Logo
Alun Cox
