Question about Refrigerators
Whrilpool Compressor I just purchased a Whirlpool PN# 8201557 compressor and was wondering what the two lower line stubs was for and can I braze them shut, also does this compressor have oil in in new or do I need to add oil.Compressor is an Embraco EGY80HLP
  • 20 Answers
They are oil cooler lines. Your unit does not have an oil cooler so leave the plugs in & don't mess with them. Trust me just put the same compressor in the same model today. Appliance tech 10 years.
Posted on Nov 16, 2010
Will the 8201555 compressor be an adequate replacement?
According to the information from your model number given the compressor should be 8201557 but that changes to W1039990 this is a complete kit. But if your good at changing this you can use a FF8.5HBK compressor which will be about a third of the cost. I hope this helps. Good Luck
Mar 24, 2016 | Jenn-Air JCD2297KEY 36" 22 Cu. Ft....
I purchased an air compressor and forgot when I purchased it
go back through the cheque book stubs , finance statements , bank statements or receipts and see if you kept a record.
May 20, 2015 | Air Tools & Compressors
Repair broken line on compressor
My name is Peter. I am a retired field service refrigeration technician.
I do not think you want to try and do this. First, The EPA has a $27,500.00 fine for non qualified people handing refrigerants.
You need to:
1.) Braze a 'T' valve on the stub end tube on the compressor. Crimp and braze one end of the 'T' valve.
2.) You need to replace the refrigerant filter. This is tricky so you do not braze the filter connections closed.
3.) You need to get a vacuum pump, connected to the 'T' valve and hold the vacuum for 10 minutes. The vacuum test for both leaks and pulls out the moisture in the system.
4.) You need a 32a refrigerant gas tank.
5.) You need a dual gauge, 3 gas hose assembly, arranged with the refrigerant tank and the vacuum pup to suck the refrigerant in the seal system.
6.) The amount of refrigerant is on a label on the side wall of your fresh food section. Too much or not enough refrigerant your unit will not cool.
7. You measure the amount of refrigerant in ounces using a scale with the gas cylinder setting on top of the scale.
A repair of this nature if I came to your home would be about $450.00+.
You can go to a "Sears Outlet (Scratch & Dent) Store", and same several hundred dollars on a new unit, with a one year warrantee.
Mar 06, 2015 | Refrigerators
Location of bullet piercing valve on sanyo sr4433s compact refrigerator
Does the unit have a manufactures process stub on the compressor casing. That is where I put piercing valves to add refrigerant. Remember that EPA does not allow piercing valves to remain on system and the hole it forms has to be brazed shut. So if it does have a process stub place the peircing valve close enough to the end so you have enough stub to pinch off to braze thehole shut.
If there is no process stub, then install piercing valve in a convenient location in the suction piping and pierce the line. Remove the refrigerant and install a "tee". On one leg of the "tee" install a schreader valve pressure tap and rebraze the joints. Perform and pressure and vacuum test to check for leaks and weigh in the correct amount of refrigerant. Once your proficient at this procedure, it should take about 60 to 90 minutes depending on obstructions around compressor.
Just a comment, low air flow on evaporator give that same indications as a low charge. Make sure the evaporator fan is working and you have good air flow through evaporator section.
Hope this helps
Dec 09, 2014 | Sanyo Refrigerators
Ad50uss is not producing water. Fan and compressor is running . Coils are not getting cold, is refrigerant low? Or could it have a leak? How do u check for refrigerant leak and how do u add refrigerant and...
Compressors have 3 or 5 tubes coming out of the can. Probably 3 in this case. The largest is the suction and the smaller one is the hot gas line. The 3rd is crimped and brazed over. The suction line should be cool or cold (no frost or ice) and the small one should be hot. Be careful of fans. Also, that small line is normally hot enough to burn you. If they are the same temperature, its either low or out of refrigerant (Very common), the liquid line could be plugged (Rare), or the compressor is not pumping (also rare). From here on, you need a compound refrigeration gauge and a line tap. An amp probe would be nice but not needed at this point. If you have an amp probe and the compressor is running and not pumping, the amps will be lower than the name plate RLA or FLA by quite a bit. The name plate should tell you what type of refrigerant it takes. 134A is the new standard but it could be different (R12). Knowing the right type is a must. I have seen compound gauges, line taps, and R134A in hardware stores but you can't add any refrgerant on less your sure no air has gotten in. If the pressure in the suction line matches up close to the ambient temperature when the compressor is off, it has refrigerant. With the gauge on the suction line, start the compressor. If the gauge drops into a vacuum of 25 inches or more, the compressor is probably OK but the refrigerant is gone. If the leak is on the suction side, there will be air in the system. The moisture in the air will freeze immediately at the metering device and it wont get cold. If it all leaked out its another whole process to find and repair the leak, evacuate the system and weigh in the proper charge. I hope this helps. There is a whole process for all of this. Let me know if you have the equipment. I'll get you through.
Oct 14, 2013 | Whirlpool AD50USS Dehumidifier
How to add freon to a Haier hwr10xc6 Thru-Wall/Window Air? i accidentally damaged one of the copper lines & all the freon came out but i welded it back together put how to at it & where? help!
If the unit has no existing service valves you will have to purchase some - and braze them into the freon lines. Valves (with valve cores) can be purchased at a AC Supply house fairly cheaply and then you can braze them into the lines. One in the suction (big line that gets cold) and one in the liquid line (the one that gets warm). NOTE: be sure NOT to weld this into the 'discharge line' (one straight out of compressor).
Once you have the two valves welded into the unit - you can then charge the unit.
Good Luck!
Jun 24, 2011 | Haier hwr10xc6 Air Conditioner
Will not cool, making a clicking sound, is this worth a service call? Whirlpool ed5fhexmq
Good day,
The clicking sound your hearing is the compressor trying to start and cannot, thus no cooling.
If you remove the back cover on the rear of the machine, you will uncover the compressor. It's the large round item with refrigerant lines welded to it.
On the side of the compressor is a cover plate that covers up the starting components of the compressor. The consist of the thermal overload protector, the start relay, either solid state and on some models a start/run capacitor. They are pressed onto 3 pins sticking out of the compressor.
You will need a VOM meter to continue testing.
With the components prying them off, set the VOM meter to Ohms. Test for continuity to all 3 terminal. If O.K. check each terminal to a clean bare area of one of tubes brazed into the compressor. The resistance reading should show zero ohms. Any reading means one or more of the windings is grounded, and the compressor is bad.
If everything test good to this point, you can take the start components to any decent sized appliance parts house. They will be glad to test them for you. Replace any testing bad.
If they all test O.K., then the problem still lies within the compressor and you will need the service of a qualified tech.
Jun 13, 2010 | Refrigerators
Whrilpool refrigerator model ed25te will not cool or freeze. lights are on, fan works
Your compressor may be trying to start and have a bad start capacitor, start relay or overload. If you hear the fans that tells me the thermostat has also told the compressor to start. Unplug and pull away from the wall. remove lower cover over the compressor area and feel the compressor on the top. If too hot to keep you hand there leave the refrigerator unplugged until we locate why the compressor is trying to start but will not. tell me the age of your refrigerator. I will keep checking for a response from you and will be here to help, Thanks, Sea Breeze
Jan 16, 2010 | Whirlpool ED2SHGSM Side by Side...
Installing compressor
It is likely you received a service port necessary to remove and replace the refrigerant in the failed system. Add a photo? It should be capable of clamping around 1/4 or 5/16 copper tubing and then piercing through the tubing via a schrader valve in the 5/16 flare nipple. Needs to be capped with a metal cap when you complete the job. Be sure to neutralize if you have an acid burnout condition from the failed compressor... copper windings burning in the absence of oxigen with all that hydrogen rich coolant makes for very high H+ concentration (i.e. ACID). The pH is minus the log of the hydrogen ion concentration so that number will be low.
1) add the service port
2) using your service hose and a transfer pump, remove refrigerant
3) test for acid and neutralize as needed, replace filter dryer anyway
4) replace compressor with make-up oil as measured from the failed unit and any collected with the refrigerant... use new oil only
5) pressure test with dry nitrogen
6) vacuum and hold 26+ inches Hg, more in cold areas
7) charge refrigerant in by weight specified on label
8) allow to equalize before starting, do not start in extreme cold since liquid refrigerant could be in the lines
9) recycle contaminated or acidic refrigerant
10) test the charge using a superheat/subcool setup if the system is not performing satisfactorily
Nov 07, 2009 | Refrigerators
Replace compressor
This type of work is normally performed by a certified technician. System refrigerant must be recovered prior to working on the system. After refrigerant is recovered from the system the lines can be removed from the compressor stub tubes by heating up to the flow point of the solder used. Number 15 silver solder has a flow point of 1385°F. Re-brazing the lines to the replacement compressor is best done after cleaning the line and using a small amount of flux. I use #45 silver solder to connect the lines to the compressors on a replacement. Flow point of #45 is 1185°F. The system filter/dryer should be replaced. After all connections are made a vacuum must be drawn on the system to remove air and none condensible gases and moisture. Refrigerant charge is critical on these system and should be weight in according the the amount stated on the name plate.
Jun 29, 2008 | Refrigerators
Refrigerators Logo
983 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
