Question about Electronics - Others
My laptop does not recognize usb flash drives, while my desktop does. I have an HP Pavilion running windows XP. Are there any drivers to install so these flash drives/mp3 players/camerasmight be recognized? Thanks,
  • Anonymous Jan 15, 2009
    I have downgraded Windows Vista to Windows XP SP2. When I plug the flash disk the dialogue box appears saying "NO DISK FOUND".
  • Anonymous Mar 19, 2014
    Needs instructions for Maxwell usb 360
    Flash Drives
  • 661 Answers
Some USB flash disks need to draw too much power for use on particular laptops,  as Laptops tend to have USB ports which only have a low current draw,
the only way around this is to buy a "Powered" USB Hub (IE a USB hub with it's own plugtop power supply).
My Portable HDD is exactly the same way, and doesn't work on some laptops for this very reason.
Posted on Oct 29, 2007
My laptop doesnt support flash usb drives any says that the usb drive not recognized
Check to see if the USB drive works on some other PC or laptop, if it does. Then its your laptop, see if your laptop has the chipset and USB drivers installed. If your OS is 7 32 or 64, you will need to check it out in the computer properties before visiting the link below. Note this is manufacturer of your laptop website, HP.
But if it doesn't work on the some other PC or laptop, then its pen drive itself.
May 18, 2014 | HP Pavilion Computers & Internet
My Free Agent Go shows up with a yellow exclamation point in "other devices" in device manager. It's not recognized anywhere else. I also notice that my computer says I have another hard drive...
> Seagate ST3200826AS
This is a Seagate 200GB SATA-interface disk-drive.
Open "My Computer", and point at the icon for 'C:' drive -- is it a 200GB disk-drive?
Double-click that "yellow exclamation" item. Click "install new driver" or "update driver".
If Windows asks permission to access the Internet to search for a new driver, allow it.
Note that the USB ports on some laptops are "weaker" (same voltage but lesser amperage) than USB ports on some desktops. So, your FreeAgent might not be getting enough power to function correctly. There exist 'Y' USB cables -- connect the 'Y' to 2 USB ports on your computer, to draw twice as much power.
Oct 31, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Usb port not recognized in windows xp
Here are a couple of articles that might solve your issue:
Apr 23, 2010 | Microsoft Windows XP Home Edition
Flash drive isn't being recognized need to back up
Regarding on your problem, in windows xp and up version of windows operating system, plug and play device is easy and no need to install its drivers manually cause the computer will automatically install its drivers. But in the case of Windows 98 you have to install your USB Driver manually in order to be recognize by the system. So my recommendation please insert the CD driver or load the driver of your USB and run the setup.exe to install the USB Driver.
Aug 03, 2009 | IBM ThinkPad X20 2662 Notebook
SeagateFree Agent Go 120 G.B external portable hard drive When I connect that in to my lap top (HP Pavilion) windows can recognize the hard drive and once I connect that same one in to my desktop windows...
you will need to install the drivers for your drive.
xp doesn;t recognize 2.0 usb unless you install drivers and have a usb 2.0 port
but install the drivers and you should get it to recognize
you can go to control panel, system and device manager.
look for a usb device that is not working and right click install drivers or update drivers.
See if it comes up.
Once it does you will see it in the device manager under disk drives
Jun 05, 2009 | Seagate FreeAgent Go 120 GB USB 2.0 Hard...
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
XP on HP Pavilion dv2000
For the laptop with no hard drive detected, this is most likely because Windows XP does not recognize SATA drives by default, which the laptop most likely has. To solve this, you will need to enter the BIOS setup utility (most likely Delete or F1 on startup). From there, you will need to change the drive mode to Compatibility mode. I'm not sure where this would be, but if you check in your laptop manual, you can probably find this somewhere.
For the 2519TU, download and install this for the LAN driver: it should work just fine.
Dec 23, 2008 | HP Pavilion dv9000z Notebook
My Device Manager doesn't recognize my CD/dvd drive.
its either yr hard ware is bad or that the drivers have not been installed. if u r using windows NT,XP then yr cd/dvd player is bad cos xp should installed most cd rom drives.
thank u
May 29, 2008 | HP Pavilion a705w PC Desktop
Kingston 4GB Data Traveler USB 2.0 flash drive not recognized by eMachines T1090 with Windows XP Home Edition. Says it needs a driver????
probably,the driver was not installed by default.
1. launch the flash drive web site and download the driver for flash drive.
2. test the flash drive with windows xp service pack 2 operating system,if it works without a driver. then providing a driver for your window will do.or upgrade the os
Apr 20, 2008 | Computers & Internet
HP Computers using XP will not show drive to which Western Digital 320GB external harddrive is connected
Your usb device could be finished or your USB ports may not be strong enough/ enough power to run the device.
Jan 13, 2008 | Western Digital 320GB MyBook External USB...
Electronics - Others Logo
1,002 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
