Question about Sharp AR-M277 All-In-One Printer
Scanner hello.  We have the AR-M277, with scanner function.  We are able to scan documents and send to email, however we can not "save" our email addresses, and must re-enter them again and again.  Two staff members addresses have been saved, but both neither of them are still with our organization.  I have read the online manual several times, but can't find any reference to saving frequently used addresses.  Also, cannot erase the two that are in the address book (each one appears several times). Please help! Thanks!
  • Anonymous Mar 12, 2014
    How do I save a email address to the printer
  • Sharp Master
  • 1,113 Answers
If you go to copiers web page you will find address book in that, to axcess web page type in copiers ip address in web browser (explorer) , you can find copiers ip address by printing out config/setting page of copier or looking at print driver port setting on pc, a IP address look like this 123.123.001.023
Posted on Oct 29, 2007
  • Soulvisitor
    Soulvisitor Oct 31, 2007
    Thanks for trying my instructions , this is how it is done!!! If you cant find your IP address then try this....press custom setting button, then list print on touch screen, then printer test page on touch screen then nic page on touch screen, now a page will print on is your IP address, type that in internet explorer address bar and your copiers web page will show in their you will find address book.....
    From a sharp tec!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!1
SOURCE:
How to scan and send document
Place your document face down on the scanner bed. Press the button that starts the scanning process depending on your scanner or printer.
Save the scanned file to your computer by clicking "File" in the menu bar at the top of the screen, then choose "Save as." Choose the folder in which you wish to save the document from the drop-down menu in the window that popped up during the saving process. Choose a name for the document, then click "Save."
Sign on to your email account, then choose "New" or "Compose" to start a new email message. Click on "Attachments" or "Attach." Wait for a new window to pop up, then choose the file you scanned from the folder where you saved the document.
Wait a few seconds for the file to attach, compose your email message, then click "Send." Your scanned document will now be sent to the recipient's email address.
Aug 22, 2013 | Office Equipment & Supplies
How to use Epson nx125 printer to use scanner and send on to email address
first scan the document as a JPEG file. save then attach the file to the email that you will send s35
Sep 27, 2011 | Epson Stylus Multifunction Inkjet Printer/...
How to send scanned documents abroad
Place your document in the scanner and choose a low resolution. Although scanners allow you to choose a high resolution, that feature is better suited for transferring photographs into your computer for editing. For documents, a resolution of 100 dpi (dots per inch) is a good choice.
Open your computer's Control Panel and select the "Scanners and Cameras" icon to open the scanner wizard. Follow the instructions to choose a location to save your scanned document. Create a new folder on your desktop, making it easy to locate the file later. Scan as many documents as needed to this folder.
Use your email account and create a new message, inserting your intended recipient's email address in the "Send to" field. You must type in the email address exactly.
Look at the top of your email window to find the "Insert" menu. When you click on it, a drop-down menu will appear, select the "Attach a File" option and choose the location of your document.
Highlight the desired document in the folder and double-click on it to attach it to your email message. Check to be sure the document attaches by looking for the file name in the "Attach" box above your text.
Repeat Steps 1 to 5 if you need to attach more documents. Send your email as usual.
Best of Luck!
Sep 06, 2011 | Computers & Internet
I am an IT pro who has an AR-M355U. We are having a problem with some new email addresses we entered. We changed the suffix of the address to a new service, and the decive stopped sending scans to our...
CE-O3 = The specified server suspends reponse during transmission of images.
Cause: Improper connection of the network cable, An error occurs in the SMTP server/FTP server/ NTS
Check: Check that the network cable is properly connected.
Check the SMTP Server/FTP server for any trouble.
Aug 23, 2010 | Sharp AR-M277 Black and White Copier
How to scan a document using a Sharp copier model number AR-M277.
Requires optional network scan kit. When installed it comes with software for scanning
Jul 17, 2010 | Sharp AR-M277 Digital Copier Copier
Send scanned document too the computer
For this issue that you are having. You need to have the printer connected to your network. You need to have the manual for the printer setup. Once it is connected to your network. You will be assigning an IP address for the printer. You need to add it on your printer list using its ip address. Once connected, try to go to the printer itself. Look at the menu and look for the scan folder. The scan folder must contain the ip address of the computer you are sending the copy to and also the exact location of the folder it will be saved. Onced setup, all you have to do is to press the scan button then it will automatically save it to your preferred computer folder. Please be also noted about the file formats that your scanner will create. Usually, people uses jpg,jpeg but i recommend .Tiff cause it won't loose the quality of the scanned picture or document
Sep 05, 2009 | HP J4680 Office Jet All-In-One Printer
We own a Sharp AR-M277 copier, scanner, fax machine that we use on our network. The scanner feature worked great, however, after 500 scans it stopped working. Someone told us that it was just a trial &...
The machine was put in a demo mode for scanning. What you will need to do, is contact an authorized Sharp dealer and purchase an MX-NSX2 kit and that will enable scanning and also purchase you a copy of a program called Sharpdesk.
May 13, 2009 | Sharp AR-M277 All-In-One Printer
Sharp AR-BC320 Scanner Setup
login to the copiers web interface (the ip address of the printer ex: 192.168.XX.XX) you will see Network Scanning. Here you can change all the scanning e-mail options.
Aug 11, 2008 | Sharp AR-BC320 All-In-One Led Printer
Sharp AR-M450 can't scan to e-mail
Check your primary and secondary dns entry.Also a return admin address is required.
Regards Ed
Mar 27, 2008 | Sharp AL-1641CS Laser Digital Copier
Copier with scanner:programming email addresses
step 1...finding ip address of copier.....On computer if running xp, go to start then control panel then printers and faxs, here you should find a icon that is for your copier, right not left click on it, then choose properties, then a box opens select third tab up the top named ports, a new box appears....now in this box there will be a tick in a tiny box near where is should say IP.......just place mouse near this tick leave still and on screen will display IP   111.111.111.111. ....write your version of that number down.(???.???.???.???)  close/ cancel all windows that we have left open. (this procedure can also be done via copier keypad as instructed previously)
step 2 openning up copier webpage....Open up the program that you use to explore the WWW, usally explorer... like this window you can see now in front of you up the top it says www.//fixya.etcetc ... in that spot put in the number you wrote down like 123.456.789.111 nothing else...hit enter and you will browse to copiers web page that has the settings for saving addresses in copiers address book.
If this doesn't work then you do not have the rights on your pc terminal or your not running xp or your computer or your pc is not set up to print to this copier, if this is the case then it needs to be done at the server that is connected to this copier.
Oct 30, 2007 | Sharp AR-M277 All-In-One Printer
Sharp AR-M277 All-In-One Printer Logo
432 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
