My printer keeps pulling the paper by the right side and then jams. I think it's a problem with the roller and don't know what to do. I have never had any problems with this printer before and this is really frustrating! Please help.
First look through the paper path, and make sure there are no obstructions.
Look where you put the paper in. See if you can see inside there and see the roller that turns and picks up the paper. If you can, make a mixture of alcohol and a little dish soap. Damp a rag with it, and reach in there to clean the rollers. See if the rollers will turn manually, but be careful not to force anything. Another way to get to the whole roller, would be to start making a print, while watching the rollers. As soon as the rollers have turned half way, unplug the printer. Now you can reach the other side and clean that.
There is another way to clean the rollers. Using the alcohol mix, take a single sheet of paper, and damp one half of it with the solution. Stick the single sheet in the paper tray, and make a print, but hold on to the paper so that it doesn't feed through the machine. Do this several times, and the rollers turning against the wet paper should clean them.
Try to print again. It might take a few tries. The rollers have to turn against the paper and dry themselves off again.
If this works, then you need new rollers (cleaning them will only make them work temporarily and the problem will come more frequently until you change them).
Thankyou,
