Question about Dell E151FP 15" Flat Panel LCD Monitor
Monitor blackout and screen discoloration
I have a Dell E151FP 15 in. Flat Panel LCD Monitor that is about five years old.  It has always worked perfectly for me until recently when it started to randomly go black.  The light turned off, then it turned on again and the screen was discolored - everything was kind of washed out in a rather fuzzy red.  I rebooted everything and check that it was plugged in properly, but the dicoloration remains and it still randomly goes black.  Any ideas of what this is or why it did this?  I know it is a bit old now, but the computer and all the rest of my desktop equipment, which I bought at the same time, still works perfectly.  Do you think the monitor needs to be replaced or can it be repaired?
Thanks so much!
    Genius:
  • 1,601 Answers
Sounds like the backlight is failing. If it is still under warranty send it back and let the manufacturer fix it.
Posted on Nov 18, 2007
SOURCE:
My Dell E151FP LCD monitor keeps randomly flashing OSD menu, help
The cable might be pinched or bad.Have you tried the monitor on another PC?
Good luck
Oct 17, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell monitor white screen
Some people have disassembled the LCDs, and resoldered all cracked or corroded solder joints to get them to work again.
Oct 12, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
E173FP monitor fix
Depending on when you bought it. There should be at least a one year warranty. If its still under warranty have dell replace it.
Mark
Mar 25, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
Dell Monitor 15"flat panel-2 Horiz. black lines
HAS IT HAPPEN ANYMORE OR IS STILL THERE.
CHECK YOUR DRIVERS, UPDATE THE DRIVERS, CHECK THE CONTROL PANAL IN THE FOLLOWING FOLDER DEVICE MANAGER, PROBLEMS REPORT, SYNC CENTER
OTHER THAN THAT TECHN SUPPORT OF YOUR VENDER WHERE YOU BOUGHT YOUR MONITOR FROM OR GO ON LINE AND TYPE THE FOLLOWING INFORMATION EXAMPLE:
DELL E151FP FLAT PANEL LCD MONITOR 2 BRUSH STROKES ON SCREEN
ENTER
SEE IF ANYONE ELSE MAY OF HAD THE PROBLEM OR TO COME FIND OUT THAT THAT WAS A RECALL ITEM FOR THAT MONITOR, JUST KIDDING, ITS WAY OUT THERE
ROD
Feb 09, 2009 | Dell E151FP 15" Flat Panel LCD Monitor
I have a dead E151FP monitor...need either a schematic or another damaged monitor
You can get repair instructions for the Dell E172/E151FP at ezinearticles.com and order transistors at AnBparts on ebay.
Nov 06, 2008 | Dell E151FP 15" Flat Panel LCD Monitor
Discoloration of the images on the Dell Flat pannel screen
Have you tried a different cable? That would account for the discoloration. That particular model came with a 15-pin analog video connector that you should be able to purchase at any electronics, office supply or computer store. You may even be able to borrow one from a friend's monitor to test and see if that works for you.
Now, about the mouse redraw issue, you may want to remove the video card from your device manager and let it reinstall. That should allow Windows to redefine mouse (X,Y coordinates) characteristics.
Nov 10, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Dell 151fp is slow to get going, fine otherwise
You dell e151fp lcd monitor may have a bad/weak capacitor on power section(primary and secondary). Just change the buldge capacitor and use the Dick Smith ESR Meter to check the capacitor esr value. If you not sure all the above, you may go to this site to get the list of bad component on dell e151fp lcd monitor. Please visit here http://www.fastrepairguide.com/monitor-and-lcd-monitor-problem-solutions/repair-dell-e151fp-lcd-monitor-with-symptom-no.html
Sep 08, 2007 | Dell E151FP 15" Flat Panel LCD Monitor
Dell E151FP 15" Flat Panel LCD Monitor Logo
131 people viewed this question
Clive
Clive
Alun Cox
