Question about Philips 26PF9946 26 in. LCD Television
Right third image filled vertical lines when hot
About 1/3 of the LCD, right side is filled with vertical lines after 15 to 30 minutes.
It looks like the pixels are longer and longer, starting from the top off the screen, until the color from the first top line is expanding to the bottom, making just colored lines on 1/3 of the screen.
Let it cool down and its working again for 15 minutes
There are 3 main circuit board in that lcd tv :
- tuner / analog board
- Backlight drivers
- digital driver for lcd itself
None of those board are sensitive to cooling with a freezing spray.
I do suppose the lcd itself have a defect, shortly after warranty of course which is very bad news.
And it looks that i'm not the only one
Did someone had this problem solved ?
  • 3 more comments
  • nz_sharky Nov 07, 2007
    I have exactly the same problem.I have dismantled the set and heated and cooled all the boards and was unable to trace the fault to a board. I am sure this is a common fault so i hope a solution exists.
  • Viva88 Nov 13, 2007
    I also have the same problem . Initially the vertical bars used to vanish now they are on all the time.
    Do you guys see the lines for all input sources HD , VGA etc .
    I am eager for a solution . Do let me know ... Viva
  • ErikSch Jul 05, 2008
    Same problem here only with a smaller part of the screen. On right side of the screen. Sometime totally black, sometimes white, sometimes a distorted view of the rest of the picture and sometimes also the "caramel-coloured" lines as in the foto that is already on the site.
    Did any of you get any service from Philips?
  • adaptable Oct 26, 2008
    Bought this tv approx 3 yrs ago. Recently right third of screen began displaying poorly much larger pixilated squares than expected, deterioating into the caramel lines as per the photo on site and subsequently ending up as fine rainbow stripes on white background. For some days this was a rare frrequency with the screen returning to normal after some minutes. Unfortunately for the past two day the screen appers to be permanently in the rainbow state despite being off for the better part of 36 hours.'s just come back on - until next time i guess
  • lotusbluete May 11, 2010
    i got the same issue with mine though on the left side of the screen... it also starting after 15-30 min...
    try to cool down the tv a little by open the topplate but with no success...
    tv was bought in june 2005...
The Philips service folks in India told me its a panel issue and panel needs replacement . They advised me to go for a new TV instead.
If you guys learn anything new ... do let me know ... Viva
Posted on Jan 05, 2008
Ive Had the same issue with my TV - and its really dissapointing to see it so well documented - obviously this is a design fault- its the last Philips TV im buying :(
Posted on Jan 13, 2008
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
Portion of the screen is very dark, gets better after 20 minutes
Your LCD panel has failed, it will be cheaper to get a new set. If I have helped you please sign my guest book
Apr 17, 2014 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
Vertical black bar on my LG 47" LCD shifting the image to the right
Two possibilities are there. The first one is, with loose LVDS cable, that connects the T'Con board to display panel. The second is the fault with its main digital processor board.
May 21, 2013 | LG 47LC7DF 47 in. LCD HDTV
Right side of screen distorted
if the distortion looks like sideway lines with weird trails and double images its most likely a tab bond issue. If its straight vertical lines then its likely the Tcon
Mar 29, 2012 | Samsung LN46A550 LCD TV
Two vertical 1'' white lines on right side of Lcd panel
If the lines are parmanent, Then suspected part is LCD Panel.
Dec 27, 2009 | Samsung 226BW Monitor
Red 2 inch vertical line on right side of Vizio TV
That problem caused by a connection between LCD crystal and matrix driver,no tools yet to reconnect that metal to crystal connector,Claim warranty right away that will multiply or became larger.
Aug 30, 2009 | V, Inc. Vizio L6 HDTV-Ready LCD Television
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Can not get a full screen lack 1 quarter inch on both side of the screen
just right click right in desktop and choice properties then setting and adjust the screen resolustion
Sep 28, 2008 | Computers & Internet
Green vertical line on the right side of screen
Warranty still alive?
Hope so; the problem could be an expensive one.
The screen appearance is controlled by allowing light from a backlight through by turning pixels off and on.
This switching is done by a matrix that turns on vertical and horizontal pixels of the right shade at the right time to produce the image you see.
One of the control elements for the vertical that controls the transmission of green light from the backlight, has died (no longer switching off and on when told) and these are normally a part of the LCD screen assembly itself and not easily replaceable.
I would be talking to Sharp - this shouldn't happen in 6-7 months of use.
Jul 09, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Philips 26PF9946 26 in. LCD Television Logo
517 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
