You have a shorted touch pad.. here is a link for a replacement.. http://www.pcappliancerepair.com/newfindform.phpIf you open up everything and examine the touch pad, you may see something that is causing the short and fix it, oherwise, you'll have to remove and replace it.. Hope this helps..
Hi, the F2 error code means that the oven is overheating for an unknown reason. F3 and F4 indicate a problem with the oven sensor, which usually requires replacing the sensor.
The F3 means Key panel (touch pad) shorted.
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Hey-- You've spent a bunch of time on this already, so let's figure it out. The first step is to check power connections. L1, L2 , Neutral for proper location and tight connections. Should have 120v and 220v checked at bus block. If these check out, then this new unit should be under warranty and qualify for service. Not unheard of bad board or loose wire on a new unit. Let a tech sort it out on site. Let me know if this info helps- have more if needed- Thanks- Ed
Well, F7 error code occures due to A = Function pad button stuck or B = Bad clock Unstick button or Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver. REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Could be one of 2 problems. Perhaps both.
Unplug the range.Access the control panel and unplug the ribbon connector from the control.
Wait 35 seconds and re-connect it.
If it continues to beep and code replace the temperature sensor.
i think f3 error code has something to do with the temp probe maybe it is the problem. the temp probe is located if you open the door directly in the back wall. it looks like a prong. should read 1100ohms the f2 error code though usually has something to do with the keypad i would check all the connections maybe they are loose.
