My pc wont boot from cd when i insert windows 8 32 bit. but it does with windows 8 64 bit inserted. how do i fix this? i need to install windows 8 32bit.
SOURCE: Dual Boot XP 32 and XP 64 on different PHYSICAL drives on same PC
So you want to merge those to make it as dual boot system on one harddrive, right? Try these steps:
1. Go to start, control panel
2. Performance and Maintenance
3. Administrative Tools
4. Computer Management -> expand storage, click Disk Management
5. Right Click the drive containing XP32 that you want to use, click format... Choose NTFS then make it as Extended Partition.
6. Reboot your computer and try to see by Pressing F8 if there's an option of what operating system you are going to use.
*Drop me a comment if that works or not so I can assist you further.
SOURCE: 32 bit program to 64 bit opperating system
From the Autocad webiste:
System Requirements
AutoCAD® Civil and AutoCAD® Civil 3D® 2009 Recommended System Requirements
Recommended configuration (excluding server components used with project management capabilities):
Note: Windows XP 64 and Windows Vista 64 are supported in 32-bit compatibility mode only.
Here's how you should be able to run it in compatibility mode:
1. Right click on the Autocad Icon in your start menu
2. click on Properties
3. click on the Compatibility tab at the top
4. check the box next to Compatibility Mode and select Vista 32 bit if it is given as an option.
I don't have Vista here, but that is how it works in XP and I did do a search and it appears to be the same in Vista.
