Question about Cuisinart DLC-10S Pro Classic Food Processor
It just stopped working
I have only used my food processor about 5 times since I purchased it about a year ago.  I went to use it the other day and it just would not work.  I put something in to chop and tried to turn it on... nothing.  Any suggestions?
Thanks,
Jean
  • 3 more comments
  • Anonymous Dec 31, 2007
    My sunbeam food processor is less than 24 months old and I would not have used it a dozen times. I have set it up as per the instructions in the manual and it still will not work. I have not dropped or misued this appliance in anyway. I am not impressed. There are no trouble shooting solutions at the back of the manual as there are with many of the other appliances I own.
    Please help, any suggestions?
    Thanks
  • Alark Feb 16, 2009
    I have used the product twice. I went to use it and it won't work at all. It has been in my cabinet and nothing has happened to the processor.
  • kashka8 Apr 02, 2009
    The soluction suggested was a relief because I know it still works... But it appears that they white tab inside the clear part (on lid) that should push down the white lttle pole to let the motor work isn't pushing it down... does that make snese? How do I fix this??
  • Anonymous Apr 26, 2009
    The directions in the solution fixed my problem but I noticed that even with the lid on, the tab in the led wasn't pushing down on the bar that runs down the side of the bowl and pushes the button on the base. I had to push down on the lid to activate the button in the base. Thank you to the person who posted the soultion, you saved me a ton of money!
  • Cynthia Simpson Apr 29, 2013
    The food you put in the top (ex. brick of cheese) might be higher than the level measure on the side of the lid. Start w/ a smaller portion.
  • 8,596 Answers
Remove the work bowl from the base of the food processor, and separate the bowl, lid, and pusher sleeve.
Plug the base into the wall outlet, turn the food processor ON, and then use a pen to press in the dark grey or black button on top of the base of the food processor - if you hear some kind of noise, then your motor is still good.
Put the work bowl on first, with the handle facing the front of the food processor.
Put the lid on, with the hollow feed tube facing the back of the processor.
Put the pusher sleeve in the lid, with the sliding lock switch facing the front of the processor.
Your processor should now turn on.
If your food processor still does not turn on, call Cuisinart and see if you are eligible for an in-warranty repair - it has a 3-year warranty.
-Tha Mp3 Doctor (also loves Cuisinart)
Posted on Mar 24, 2009
Just stopped working
Most often when that model processor stops working it is associated with the mechanisms in the lid and bowl that activate the safety switch that prevents you turning it on when the bowl & lid is not on correctly. The mechanisms are not repairable, the fix is to replace the bowl or the lid or both. A proper KitchenAid service agent should have both in stock, take your complete machine in so that the faulty part can be identified.
Nov 26, 2017 | KitchenAid KFPW760 12 Cups Food Processor
Timer works but machine doesn't turn/run
It sounds as if you may need a control board for your food processor, it could be that there is a loose or burned connection inside your unit and could be fixed by disassembling it. another option is to call the Cuisinart phone line located on the bottom of the processor or on the user manual. Unfortunately most control boards are too costly to repair or replace, and your machine is not under warranty. most times they are deemed a ``throw away``. hope this helps.
Thanks
Oct 11, 2009 | Cuisinart SmartPower Premier Duet...
My B&D food processor stopped working all of a sudden...
Unfortunately, those units are designed to be repaired or worked on. If it isn't working anymore, it needs to be replaced. It has a one year warranty from the date of purchase. Please call 800-231-9786 which is Black & Decker's customer service number so we can see what we can do for you.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 13, 2009 | Black & Decker FP1445 Food Processor
The Blender attachment will not turn, just grinds and smokes.
The motor shaft that spins the teeth that are on the base of the blender may be frozen up for some reason. If you purchased the duet within the last 3 years and have a receipt, call Cuisinart to get it repaired in warranty - even if you don't have a receipt, your serial number may still save you. If you purchased it more than 3 years ago, let me know.
Mar 12, 2009 | Cuisinart BFP-703 SmartPower Duet Food...
Lid for Bravetti Platinum Pro
Go to europro.com, or call 8007987398.
JimP
Aug 09, 2008 | Bravetti Platinum Pro Quad-Blade Food...
Can't get it to start
I have a Bravetti EP 199, and I have the same problem. I can not get it to start. It is dead. Cold dead. Do I understand you posted your problem since Nov. 18, and you are waiting to get help?
Nov 18, 2007 | Bravetti Quad Blade Food Processor
You can find the manual on Hamilton Beach's web site: http://www.hamiltonbeach.com/use-and-care/use-and-care.php
Choose your product from the drop-down menus. Its not a great copy, but its legible.
Nov 05, 2007 | Hamilton Beach Chefprep 70700 Food...
Cuisinart mini prep processor blade not rotating
Replace work bowl and blade - see if it resolves the issue.
Oct 29, 2007 | Cuisinart DLC-8S Pro Custom Food Processor
Cuisinart DLC-10S Pro Classic Food Processor Logo
4,415 people viewed this question
Top Cuisinart Food Processors Experts
Colin Stickland
Colin Stickland
Greg Cann
Greg Cann
Are you a Cuisinart Food Processor Expert? Answer questions, earn points and help others
