Re: I bought a truck that has a boss bv9564b1 and it has...
From one of the other BOSS manuals, itt says the default password for system settings is "888888" and the default password for the DVD parental child lock is "0000" and any other password is "123456"
My dad bought a used CR-V that came with the exact same deck as you. I haven't had a chance to try it out yet, but in the manual for the Boss BV9555, it actually mentions the password screen as opposed to the useless manual for the BV9560B. It says the default password for system settings is "888888" and the default password for the DVD parental child lock is "0000" and any other password is "123456"
Reset a Forgotten Pass Code To reset your pass code after you've forgotten it:
Go to My Xbox and open System Settings.
Select Family Settings, Console Controls.
Enter an incorrect pass code.
You'll be told that your pass code is incorrect. SelectReset pass code.
You'll then be shown your pass code question and asked to answer it.
Set a new pass code, following the directions in the previous section.
If you've forgotten the answer to your pass-code reset question as well as your pass code, call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
I think you'll have to hard reset your device, in order to get passed the password request procedure. You, most probably, know that a hard reset will return your device to its factory defaults, thus deleting all the applications you have installed, as well as all your personal data and settings. Anyway, to hard reset your device, press and hold both the SEND and END buttons, and, whilst keeping them pressed, press the reset pin with the stylus pen. Release the keys when a confirmation request screen comes up. Follow the on-screen instructions (if I'm not mistaken, confirm the hard reset procedure by pressing the SEND button).
Hope you are able to have a fully functional device again soon.
Best regards,
Carlos
YOu can reset bios password with 2 method. (1) open back cover of
laptop then find motherbord .Pull cmos cell from motherbord for 15
minutes then again put it in it's position .then it not ask for
password. (2)You can clear password with jumper settings find jumper on motherbord named clear cmos it has 3 pin .1-2-3 Put jumper in 2-3 position then again put it in 1-2 position then check . Let me know if you need more assistance. Thanks.
Is that a Bios password? then take out its cmos battery for a short time then place it back again this should rest to its default configuration without the password or clear it using its cmos reset jumper header on the motherboard. Consult manual for more info.
Do this when unit is off and unplugged to source outlet. Touch first the frame of your case to free you of static.
If this password is from user accounts. Log on to it goto control panel goto user account select account to be set with your password enter old pass,new pass then confirm it. your now set. Do this changes using account with administrator privilidge.
