Question about HP PSC 2355 All-In-One InkJet Printer
Paper error message, out of paper, but has paper, will not pick up. Have changed paper, reset many times, disconnected printer, etc.
  • 20 Answers
Give the paper slot  a very good clean it is probably a sensor that is dusty compressed air is best if you have it
chris
Posted on Oct 29, 2007
False paper out message
An 'Out of Paper ' error message displays on the product control panel display, and the product does not pick up or feed paper from the photo tray.
Try to reset the printer:
  • Disconnect the power cord from the electrical outlet.
  • Disconnect the USB or Ethernet cable from the back of the product.
  • Disconnect the power cord from the back of the product.
  • After 30 seconds, connect the power cord to the back of the product.
  • Connect the power cord directly to an electrical wall outlet.
  • Connect the USB or Ethernet cable to the back of the product.
  • Try the print job again.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Nov 16, 2012 | Xante ScreenWriter 4 Laser Printer
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
Printer error as stated "Printer Mispick [Enter] to resume." There was a mispick but that was corrected; however the error message is constant.
Hi:
I own a HP Laserjet 3330, and usually all that it takes to fix this problem is cleaning off the paper pick up roller with a damp cloth.
It is having trouble picking up the paper sheets, and you will get the error time after time. It seems that the recycled paper is worse than others. Remember to use a cloth dampened with only water, as other cleaners will dry out the pick up roller
Oct 26, 2009 | HP LaserJet 3330 All-In-One Printer
HP 5610 all-in-one fake "paper jam"
I request you to please perform the below steps to reslove false paper jam..
Step one: Perform a partial reset
  1. Disconnect the power cord from the product.
  2. Press and hold # and 3 while reconnecting the power cord to the product, and then release both buttons.
  3. Try making a color copy by pressing the Start Copy Color button on the product control panel.
    • If the partial reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next step to try a semi-full reset.
Step two: Perform a semi-full reset CAUTION: Performing a semi-full reset deletes any saved phone numbers on the product.
  2. Press and hold # and 6 while reconnecting the power cord to the product, and then release both buttons.
    • If the semi-full reset resolves the issue, you do not need to continue troubleshooting.
    • If the error message displays again, proceed to the next solution.
Sep 02, 2009 | HP Officejet 5610 All-In-One InkJet...
Canon mf3110 does not pick up paper
The unit may have a paper jam or stuck object inside, if you have experience a paper jam error before, check the printer for any object or paper stuck inside, clean roller.
Some error like this can be a problem on the feeder sensor and by this time you may need to replace and repair the unit.
Hope this initial info helps
Aug 22, 2009 | Canon MF3110 All-In-One Laser Printer
Printer won't pick up the paper in the tray to print. Keep getting out of paper message
First check if the feed rollers are 'Slick" with paper dust, if they are ,clean then with 409 on a cloth rag, and scrub till u dont see the white paper dust on the rollers, let the rollers dry, then reset the printer, by turning it off. then turn it back on ,reinstall the paper and begin printing again.
Jul 15, 2009 | Office Equipment & Supplies
Computer keeps saying ''paper out'' or ''not loaded properly''
It sounds like your sensor, clean it with a dry cloth, then check to make sure you don't have too much paper in at one time thus preventing the stack from engaging the sensor. If still a problem, disconnect all wires including power and re try, it sounds like something is hung up, it is usually dirt. Then it isn't allowing the paper to fall low enough to be picked up by the printer.
May 14, 2009 | Office Equipment & Supplies
Paper won't pick up from the paper tray. I keep getting a load error message or paper tray message no matter how I load the paper. I get the codes "A4" and "024-964" Thanks
Check your printer for paper size and type settings. Ensure they are set to letter and plain1. Also check the program you are printing from (Word, wordperfect, etc) and ensure the paper size is correct there as well.
Feb 25, 2009 | Dell 3100cn Laser Printer
"Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper jam
Don't know if it's the same problem i had but its maybe worth a try. Canon MP160
My paper went in a little, the wheels were turning but it didn't take the rest of the paper or print.
Someone replied to my problem, i tried it and it fixed 1st time. Also seems to of worked for others
Solution:- Use a piece of thin card, a magazine cover is what i used, make sure its A4 size then try to print something, as the paper starts moving push it through! and hey presto it worked for me, everything printing fine now
Nov 12, 2007 | Canon PIXMA MP600 all-In-One InkJet...
HP PSC 2355 All-In-One InkJet Printer Logo
mukhtar21 shaikh
mukhtar21 shaikh
