In our country we use 220volts 60hz..then our washen came from other country it have 220v 50 hz waterpump and it not work properly..i want to know how to convert the pump to 60 hz
SOURCE: E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
SOURCE: CMD 126 candy washing machine struggles to spin even at low load
hi your balt is sliping or your ford geers are ded
SOURCE: Convert US 220V to European 220V
all you need to do is to purchase a power converter also known as transformer that converts the European 220v to110 v, so that American appliances will operate on European current.
