Fuji FinePix Z100fd Digital Camera Logo
Posted on Jun 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Communication error When i connect my Fuji Z100fd to the computer with the USB lead i get a blank white screen with just a USB icon in the top left corner then after waiting a while it gives a red exclamation mark and says communication error. i think something went wrong when i accidentally clicked something when i was in the middle of deleting photos from the camera whilst still plugged into the computer
John Long Shipton
Level 2:
Sniper:
  • Expert 63 Answers
  • Posted on Jun 12, 2009
 John Long Shipton
Expert
Level 2:
Sniper:
Answers
63
Questions
0
Helped
33072
Points
175
Sounds like you have corrupted or possibly deleted a Fine Pix Viewer driver software file.
Suggest you uninstall and reinstall Fine Pix Viewer.
Before you start you might want to create a backup folder on your C drive and put copies of all your photo files therein. Make sure your camera is not connected to your PC before reinstalling software.
Assuming Windows operating system click : Start, Settings, Control Panel, Add or Remove Software, then scroll to Fine Pix applications. You will probably have three to choose from. Since you don't know where the problem lies suggest you start with Fine Pix Viewer which will probably have a version such as 5.5 (in my computer anyway). Having highlighted this file click on the uninstall button.
Now reinstall from your Fine Pix CD.
Suggest you reboot so new software will recognise your camera when it is connected. With camera connected Windows will probably advise that there is new hardware and it is seeking software. Give it time and Viewer should boot up on your screen.
Anonymous
Level 2:
  • Expert 58 Answers
  • Posted on Oct 03, 2009
Anonymous
Expert
Level 2:
Answers
58
Questions
Helped
18663
Points
176
My Computer used to recognise my Finepix S8100fd and I could put pics straight into Picassa.
Now I have the Dreaded "Communication error".
As a workaround I took the 4GB SDHC card from the camera and fitted it to my "Cannon ixus 801s" which communicates with picasa perfectly via usb2.
Could I have a faulty usb cable?
I downloaded photos on computer ,now I get card not initialized ? what do I do? Its a fujifilm camera..
Insert the memory card into the camera to format it if you are receiving error messages such as "Card Error" or "Card Not Initialized." Press the "Menu/OK" button then press the left/right directional button to select the "SET" option. Press the up or down direction button then press "Set Up" and press the "Menu/OK" to access the setup screen.
Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • 2 Press the down directional button to select "Option 1" and scroll down to the "Format" option. Press the right directional button to select the format option. Press the "Menu/OK" button to start the format process.
  • 3 Move away from the target or brighten the lights if the auto focus does not work. Rotate the scenery mode dial at the top of the camera to the "Auto" mode. Press the "Flash" button to enable the flash mode to provide additional lighting if necessary.
  • 4 Manually set up the Fuji E500 camera with your computer if the computer does not automatically detect it. Connect the camera to the computer using the supplied USB cable and power on the camera. Click the "Start" button then click on the "Computer" option and select the FinePix Icon. Choose next on the download wizard to start the download process.
  • Read more: How to Troubleshoot a Fuji E500 Digital Camera ' eHow.com http://www.ehow.com/how_7636592_troubleshoot-fuji-e500-digital-camera.html#ixzz1OOyWsAIU
    I want to set up a web cam to visit with friends over the internet
    Noprob.
    Setup disc. Follow instructions, should not need clicking, but then there all differant..
    Once loaded, it may restart, once restarted and settled down, insert webcam usb, Poota should fined new hardware and load up your web cam.
    After completing and tellking you your new appl is loaded and working.
    fined icon on desktop or in your program list. Double click on icon.
    Prog starts up, come up with 4inch white screen with a poss error screen? close error screen. you should be left with a white or dark empty square, with menu at the top.
    Click on Devices/click your cam name, this will then start your webcam.
    Rem, when clicking mirror in options your pic will be the other way round, just click back.
    Hope this makes sense. Good Luck!
    Camera giving white screen when I try to download to my computer
    Pls check the Camera Mode in Menu options it needs to be in PC or toggle in other modes and check if it works otherwise change the USB cable
    pls rate me WELL !
    Communication Error
    Stop using the USB port and buy a memory card and card reader. 20-30 dollars and problem solved.
    Fuji z100fd has black/blank lcd screen?
    CCD FAILURE!
    Call Fuji for Free Repairs it is a known manufac fault in thousands of cameras , dont worry just call them see this for info on this problem
    Kindly Rate me WELL !
    this applies to all products with same problem dont worry u r included just call them and tell them abt BAD CCD !
    Good Luck !
    Hi Folks, Had my camera just over a year. Put it on today to take photos and it has come up, WHITE SCREEN, USB LOGO TOP LEFT, THEN SAYS COMMUNICATION ERROR. And thats it, cannot go any further ! I have...
    pls try to update ur firmware of camera from this link if the problem persist then take it to fuji customer care centre
    http://www.fujifilmusa.com/support/ServiceSupportSoftwareContent.do?dbid=872619&prodcat=234644&sscucatid=664260
    pls rate FIXYA for the help if u like
    2answers
    Can't get pics to my mac computer, won't transfer.
    When you get the popup from iPhoto don't click on any iPhoto buttons. Instead, click on command+tab and change to your Finder application (leaving iPhoto open in the background).
    1) Create a new folder on your Desktop or in your Pictures folder. This is where you will copy your photo files.
    2) Click on File, then New Finder window. Size these finder windows so you can see both of them at the same time. In the second window, go to your computer, and then to the drive that represents the memory card in your camera.
    3) Drag and drop to copy the files from the camera's memory card Finder window to the new folder Finder window, dropping the files into the new folder on your computer's hard drive.
    4) Use command+tab to change back to iPhoto. Cancel from the import warning window. In iPhoto click on File then Import to Library
    5) In the import dialog tell iPhoto to move the photos (not to import them in their current location) so that iPhoto puts the photos in the same place it put your other photos when it imported them directly from the camera.
    If you can't do all of these steps, tell me how far you got, and what happened.
    "Communication Error" when trying to upload photos
    Try NOT connecting your camera to your computer.
    The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
    Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
    1helpful
    Charging
    No, it will not. The digital camera uses separate AA batteries, and cannot be charged via USB like say a GPS navigator..
    Top Fuji Cameras Experts
    ZJ Limited
    ZJ Limited
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Fuji Camera Expert? Answer questions, earn points and help others
