FixYa.com
Tags:
Toshiba NAVITAR 6.0-9.0 INCH BUHL LCD ZOOM LENS, Projector Lamp FOR PROJECTORS => Model 833MCZ90
Aspen systems 275xs
By Joey2 - usenet poster
just inherited an aspen desktop from engineering, and i've been looking but
haven't found anybody mentioning if they can get vms to run on this box. i
believe linux would work and plan to try it, but would appreciate knowing if
vms would boot also. i would like to try some 7.2 features on it prior to
upgrading my production system.
thanks
mike menard
systems and data administrator
stanley aviation
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 09, 2005
Not Rated (0)
pawa
pawa - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
box has the intraserver scsi card ??
( i have an adaptec 2940 laying around i can try if this is no good.)
and a number 9 s3 variation vid card
was running nt, but has proved to be at the end
of it's useful life. hope the 64 bit operating systems
will extend our cost in these boxes.
hope to run linux as a print server for the
model shop when i'm done testing, but
would also like 7.2.x to work.
think compaq would have any heartburn if i got a
hobby license to see if it would fire up before
being honest and getting a real license if i use it
for work ?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Melissa
Melissa - usenet poster
Rating: 0%, 0 votes
I have VMS V6.2 running on an aspen alpine 275XS, but have not
tried updating to VMS 7.2.  In my system, I have PROM version
X4.4-4165 Oct 3 1995 9:45:57; an SMC EtherPower 10/100 Fast
Ethernet PCI adapter; and a ZLXp PCI Graphics board.  I am not
sure about the SCSI.
I would be interested in hearing of your experience if you try
it with V7.2.
John Hasstedt                     Email: John.Hasst @sunysb.edu
Physics & Astronomy Department    Phone: 631-632-8169 or 631-632-8153
State University of New York      FAX: 631-632-8573
Stony Brook, NY  11794-3800  USA
Solution #3
Not Rated (0)
Cornish
Cornish - usenet poster
Rating: 0%, 0 votes
I've got exactly the same configuration (Durango II) and also have had good
luck installing V7.2 on it.  However, I cannot say the same for V7.1 as the
CD boot process blows up shortly after the "OpenVMS Alpha Version V7.1"
message with some barf about device not in the config tables (I'm not at the
office at the moment).  I seem to recall that when we got this box, there
was a cover letter with a diskette containing a driver that was to be
installed in SYS$LOADABLE_IMAGES to fix this very problem.  It seems that
V7.2 has the appropriate support built in.  Something about the
SYS$PKWDRIVER.EXE "IntraServer" it seems to me.  Anyways, I've tried the
"dual device boot" technique of
boot -fl 0,80000 dka600,dva0
in the hope that the V7.1 CD would prompt for the SYS$PKWDRIVER.EXE from the
floppy (which it does) but bugchecks shortly thereafter.
If anybody knows the magic spell to get V7.1 loaded on this configuration,
I'd appreciate it.
Curtis
A rather interesting "feature" of this box is that is tends to lock up
completely when doing large amounts of I/O.  And I mean COMPLETELY - no
amount of CTRL/C or CTRL/Y or even CTRL/P for that matter will save it,
doesn't even bugcheck.  The only fix is a hard reset.  I know that this is
not OpenVMS doing this but likely the 3rd party SCSI driver.  Anybody else
see this behavior?
Larry D Bohan, Jr <LBo @dbc.spam_less..com> wrote in message
Solution #4
Not Rated (0)
Ranny
Ranny - usenet poster
Rating: 0%, 0 votes
On Mon, 15 Nov 1999 15:58:18 -0700, "mike menard"
well, I have a Durango 500 II, (circ 1997) that
works fine w/ v7.2
the most important part is obviously
a supported disk controller.
if you're not going to do X, the graphics card would
be less a concern also.
                        Aspen Systems Durango Workstation
SRM Console X4.7-393            VMS PALcode V1.19-9, OSF PALcode
V1.21-8
DECchip (tm) 21164A-2
DECchip (tm) 21172 CIA ASIC Pass 3
MEMORY
256 Meg of system memory
PCI Bus
     Bus 00  Slot 05: DECchip 21140 Network Controller
                                   ewa0.0.0.5.0
00-00-F8-03-CE-C4
     Bus 00  Slot 08: Intel 82378IB PCI to ISA Bridge
     Bus 00  Slot 09: NCR 53C810 Scsi Controller
             pka0.7.0.9.0          SCSI Bus ID 7
            dka100.1.0.9.0         RZ29L-AA
            dka200.2.0.9.0         RZ1CB-CS
            dka500.5.0.9.0         TOSHIBA CD-ROM XM-64
            dka600.6.0.9.0         TOSHIBA CD-ROM XM-64
           mka400.4.0.9.0         TLZ06
ISA
Slot    Device  Name  Type         Enabled  BaseAddr  IRQ  DMA
0
        0       MOUSE      Embedded        Yes     60      12
        1       KBD            Embedded        Yes     60      1
        2       COM1         Embedded         Yes     3f8     4
        3       COM2         Embedded         Yes     2f8     3
        4       LPT1          Embedded          Yes     3bc     7
        5       FLOPPY      Embedded         Yes     3f0     6       2
Can you Help with these Multimedia Projector Replacement Lamps problems?
magnavox replacement remote...
a some where to purchase one in... Answer This...
serial port
a serial port was broken off... Answer This...
image is flickering
The ?flickering? of the... Answer This...
Sony vpl-vw100 bulb?
My projector has been clicking... Answer This...
Necht cooker, hob, extractor
Hi there, Not sure if you are... Answer This...
Repair Service
Find Multimedia Pro. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
