Toshiba Satellite L25-S121 Notebook Logo
Posted on Jun 12, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba Satellite L25 series laptop doesn't power on
I have a Toshiba Satellite L25 series laptop that just won't turn on. I've tried taking parts off to see if anything is causing a short, but I've gone down to no screen, no wifi, no fan, no memory, no HD, no DVD, no battery and I still have the same problem. As I use the plug to feed it power, when I try to turn it on the power light comes on for about one second, and then goes off. I didn't hear any drives or fans power up when I had it plugged in as I tried this. I'm beginning to think it's a chip on the MB. Any suggestions?
Anonymous
Level 2:
  • Expert 99 Answers
  • Posted on Jun 30, 2009
Anonymous
Expert
Level 2:
Answers
99
Questions
Helped
64305
Points
181
Its a fried motherboard. any questions you can email me at [email protected]
Toshiba satellite l25-s119 internet won't work.
Wired or Wireless? Try a Ethernet Cable to verify the ISP is sending a signal. Try another broswer.
Wher i can download L25-s1194 vga driver for toshiba
http://download.cnet.com/vga-driver-ati-8/3000-18492_4-197341.html
http://download.cnet.com/1t2xw26-exe/3000-2122_4-120557.html
if these packages are not the right
http://download.cnet.com/2000-20_4.html
on the home page you should see a search tab just type in what you are looking for
you might have to try a few times to get it right
hope it helps you
Starts up, i can see the first start up page after that just a blank black screen with just a blinking cursor ........... plz help james b its a toshiba satellite l25-s121
either a faulty hard drive, or memory needs reseating,
or dodgy bios.
power off laptop.
take out battery, unplug power
hold power button for 60 seconds
inser battery,, plug in power
and then it should work hopefully
I've installed 2 gigs of ram and it won't recognize the second stick.
The L25 series laptops can take a maximum of 2GB of memory, 1GB per slot. It should be DD2 PC-5300 spec RAM. Below is some specifications the memory should meet alongst with a compatible part number.
Part #: CT540972 • DDR2 PC2-5300 • CL=5 • Unbuffered • NON-ECC • DDR2-667 • 1.8V • 128Meg x 64
Cheers, Ravi Shanghavi
Toshiba Satellite L25-S119 laptop-No image on screen but the fan powers up when the power is turned on. The Power button illuminates then turns off but the fan continues to run.
well your leaving a lot to the imagination..is the hard drive light working..plug it into a external monitor then boot it..then we can go from there..
I changed the hard drive in my toshiba satellite L25 now it will not power on
Did you take out the battery when you changed the hard drive. It still has power in the circuits when the battery is in. You might have fried it. I would try taking out the battery and push the power button a few times (to discharge any power in the board) then make sure the hard drive is inserted properly. Good luck.
1helpful
2answers
Toshiba laptop power cable won't charge battery
I had the same problem with my HP laptop some years ago. you have a broken cable/cord and it is the part that is permanently attached with your power pack. If you look at the cord that plugs into your laptop, you can be able to see the faulty part of it. it is usually very flexible or swollen. You can either take it to an electrical technician to change that part of the cord. Your power pack is still ok, but have the technician to check it out first before you change the cord. Else, you may have to get another power pack. below is the full specification of the power pack that is recommended for your laptop.
This Toshiba Global AC Adapter is a 65W external AC adapter designed to work with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers. Get an extra AC adapter to be kept at home, in the office or in your travel case.
Specifications:
* Power: 100-240V/ 50-60Hz Frequency (Universal) input voltage; 19V x 3.42A output voltage
* Dimensions: 4.25" W x 1.34" D x 1.85" H
* Weight: 0.67 lbs
* Power cord included
* Compatible with Satellite 1000, 1005, 1100, 1105, 1200, 3000, 3005, A80, A85, A110, L10, L15, L20, L25, L35, L45-S2416, L45-S4687, M30X, M35X, M40-S312TD, M45-S165, M45-S169, M45-S165X, M45-S169X, M55-S139, M55-S141, M55-S1001, M55-S1391, M55-S1412, M105-S10XX, M115-S10XX; Tecra L2 series portable computers
* One year limited warranty
Note: This AC Adapter is the direct replacement for Toshiba 60W AC Adapter (Mfr. Part#: PA3097U-1ACA) and Toshiba 65W Global AC Adapter (Mfr. Part#: PA3396U-1ACA)
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
1helpful
My toshiba satellite A200 series wont start up.when i switch the power on it just lights up.but nothing follows.
1. Remove all USB devices such as printers, mp3 players etc etc.
2. Remove the power-cable and the battery
3. Press and hold the power button for 30 seconds
4. Put the power-cable back in but not the battery and none the USB devices.
5. Turn the computer on
3answers
Toshiba Satellite L25-S119 No boot
reset bios to default try installing fresh system
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
