Question about Whirlpool LER5636P Electric Dryer
Heating element how do i replace the heating element on a admiral dryer,(ade7005ayw)
  • Dennis McFarland Jan 05, 2008
    I need to change the heat element in my Amana dryer and i don't know where it is located.
  • Nate Matter Apr 27, 2009
    I have the Admiral ADE7005AYW. The heat and light stopped working at the same time. What could it be.
  • 709 Answers
Disconnect the power.
Slide the Dryer away from the wall.
Pop up the top
You should see the heater in the back.
Remove the wires connections, and move them to the side
Remove the retianing screws
Pull the heater out.
Put the new heater in and reverse the procedure.
Posted on Nov 07, 2007
3 Suggested Answers
david04928
  • 102 Answers
SOURCE: heating element
Might I suggest this site if you are a do it your self.
http://www.appliancerepair.net/dryer.htm
You have to raise the top take off the front and the tub should come out. Wala the heating element. Hope this helped, if not let us know.
Posted on Mar 16, 2009
  • 4088 Answers
SOURCE: Can't open Admiral ADE7005AYW
Try sliding a thin putty knife rearward at each front corner of the top while lifting upward slightly. Shine a light into the joint and look for metal joining the two halves. Once the top is loose, look for screws in the inside front edges and lift up on the front panel to release. Make sure to pull the power plug while working in there.
Posted on Oct 22, 2009
I have an admiral dryer, model #ade7005ayw, that will not tumble. the motor will spin manually and the belt is brand new and properly installed. what could cause this problem?
This Admiral site lets you select symptoms, offers solutions, has videos, and instructions, plus authentic parts for ordering.
Worth a look.
My ADE7005AYW Model Overview from PartSelect com
http://www.partselect.com/Models/ADE7005AYW/Symptoms/Will-not-tumble/
Feb 28, 2015 | Admiral Dryers
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Where is the heating element on an Admiral Dryer, Model ADE 7005AYW?
pop open the top and take off the screw on each side of the front panel on the inside and your element is on the back left corner.
Can't miss it
Apr 16, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Where is the heating element located in an admiral model no. ADE7005AYW
Take a look at this video to show you how to open the cabinet. The element is on the lower right side.
Nov 05, 2012 | Admiral Admrial ADE7005AYW, ADG7005AWW...
How do you get to the element on admiral dryer model ADE7005AYW
to start, you need to unplug the dryer, then remove the front panel and look at the rear left and you will see the element. remove the 2 connectors and 2 screws holding the element and to install your new one just reverse the procedure. be carefull not to touch the new heating element coils. your skin oils will shorten the life of the element. good luck to you.
Feb 05, 2011 | Admiral Washing Machines
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Can't find the heating element on my admiral dryer ade7005ayw
Normal 0 Hi, UNPLUG the dryer! Remove the rear panel of the dryer and locate the element on the right hand side. Plug the dryer in to test to see if there is 240V going to the element posts. If there is voltage, but no heat, change the element. If it does not, you need to test the thermostats for continuity. If any of the thermostats are open, replace it. I hope this helps you.
Please let me know if this help or if I can assist you further.
Thanks
Vic
Jun 13, 2009 | Whirlpool LER5636P Electric Dryer
The black wire burnt off on the line going into the heating elem
No, you do not need to remove the drum. But you will need to remove the cover from the blower assembly. Using a volt meter, check the elements continuity to determine if it is bad or good.
Apr 16, 2009 | Whirlpool LER5636P Electric Dryer
Heating element
Mar 16, 2009 | Dryers
Blk wire burned off at heating element admiral dryer ade7005ayw
lets see hear.a loose connection draws maximum ampreage so important that any connections are clean and tight then another thing could be vent .if its is restricted at all your heater will run hotter putting stress on those connections
Dec 31, 2008 | Admiral AAV7000A
Whirlpool LER5636P Electric Dryer Logo
1,750 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
