I was using the heat and smoke started coming out of the vents. Now the heater/ac/defrost don't work, and the windows do not roll down.
SOURCE: heat stopped working in 2000 pontiac sunfire
With blower on high and tempature to max heat check to see if you have good air flow in all mode selections (defrost, vent, floor etc.). If so and you still have no heat then check heater core hose going from engine to inside car to heater core with vehicle running and coolant tempature about half on guage. If both hoses are hot and coolant in radiator/overflow bottle is full then hot cold blend door is stuck in cold position. If coolant level is low you will get no heat, check coolant level first.
