Question about Pelco Televison & Video
I want to connect two monitor with 1 dvr
Actually I want to purchase which carry 8 channel audio n video line in and carry two video and audio out because what happen when I need to see 1 channel in full screen so other 7 channel will hide so I want if I want to see 1 channel in full screen that will display in my laptop where side by side I will capture in my laptop also
SOURCE:
  • 979 Answers
SOURCE: Sci Atlanta 8300 DVR HD sound in HD channels soft - analog channels OK
Experience has shown that with this relatively new mode of transmission, audio levels can be quite dynamic. If your set provides it, you may try turning on "Audio Compress" or whatever the name might be. Could also be called Dynamic audio also or some such. Reason for all the hubbub is that along with HD, mixing engineers are also providing the most range for the audio dynamics as well the most video composition info in the new broadcasts...Accordianman.
Posted on Oct 11, 2007
  • 979 Answers
SOURCE: Audio on DVR recordings on non-digital channels squeals on playback
Try a system reset by unplugging the unit from all power, wait for 5 minutes and retry. This is an unusual problem...accordianman
Posted on Oct 15, 2007
  • 979 Answers
SOURCE: EasyCap Video Capture at Incredibaly Low Frame Rate
So is the capture 1 or 2?
Posted on Feb 25, 2008
IB4G2008
  • 3587 Answers
SOURCE: kds laptop screen is not full display side to side top to bottom
that's in settings in control panel
Posted on Mar 02, 2008
SOURCE: Sound is not recorded
Make sure that the your audio wiring is correct. The L&R audio cables from your VCR, etc should be connected to the red and white RCA jacks on the capture card cable. The small 3.5 mm phone jack from the capture card cable must then be plugged into your PC's line-in jack - usually blue. Then in the PVR application, select line-in as your source. This is necessary because the capture card only processes video. The audio signal is passed through to your PC.
Posted on Apr 24, 2008
How can I view a backup video from a USB on my laptop
You cannot. You can setup on your network and use Internet Explorer to download the video via a network connection.
Sep 27, 2014 | Samsung SDE-4002N 8 Channel DVR Security...
Speco d4rs does not show video
Make sure the connectors are functional. Sometimes just a flaw in the connector cables or the wrong type of HDMI cable can be the problem.
Nov 07, 2013 | Speco D4RS - Standalone DVR - quadplex - 4...
Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Jan 27, 2012 | Avermedia AVerDiGi SA6832E RACK 32-Channel...
We bought a house that came with a home theater system. We would like to connect a cable tv dvr box to it to be able to watch football games in hd on the big screen with the surround sound. The components...
1. Connect cable to cable HD DVR box, connect video out of cable box to Sony receiver TV video in, connect audio L and R out of cable box to Sony receiver TV audio in and connect TV out of receiver to video in of Panasonic projector 2. Connect Audio and Video out of DVD player respectively to DVD in of receiver. Good Luck :)
Oct 23, 2009 | Sony STR-DG800 Receiver
Channel 3/Camera 3 not displaying properly
try swapping the cam inputs first to rule out the unit, if not the camera may be faulty or needs setting up properly with a focus adapter, or the lens could need setting up!
when CCTV company's set up these systems they have all the equipment to plug in and focus auomatically etc..
Hope this helps!
Try looking at www.digitalvideos.co.uk (test equipment) section.
Sep 22, 2009 | Lorex L19wd804251 19 Lcd Dvr Surveillance...
I ran the coax cable from the antenna to the RF IN connection, ran another cable from RF OUT to the television and used an HDMI cable to connect the DVR to the televison. The instructions say press '2'...
Just a quick suggestion, many of those 2 then down type instruction actually mean hold the two then while holding it press the down button. Try that then if not reply back with the make and model # of the unit and I'll do a little digging for you.
Chris
May 08, 2009 | Philips DVR-1
Connection/configuration issue: I have a Denon
Just confirming my understanding of your connections :
1). The DVD1800BD output HDMI is connected to AVR3808's DVD-in HDMI.
2). The DVD/VHS recorder output HDMI is connected to AVR3808's DVR-in HDMI.
3). The DVD/VHS recorder input (S-video and L/R Audio) is connected to AVR3808's DVR-out(SVideo and L/R Audio).
Right?
What other inputs have been connect to your AVR3808?
Does the recorder have Component Video inputs?
Please also connect DVD1800BD's output(Component video, S-Video and L/R Audio) to AVR3808s' DVD-in similar inputs and try recording onto your recorder.
Actually, its possible that you may be having a HDMI HDCP communication issue(High-Bandwidth Digital Content Protection) with the source product (DVD1800BD). First check with the source equipment manufacturer for any updates to their products.
If HDMI video is not passing through your AVR3808, you can connect it thru the alternate connection method I have mentioned above.
If the connections/recording still does not happen with the added anolog cables, then let me know , we can trouble shoot it further.
I hope the above helps.
Please do rate this solution and thanks for using FixYa!
Mar 06, 2009 | Denon AVR 3808Ci Receiver
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Using an HDTV as the PC monitor via HDMI
HDMI carried audio as well as video... Make sure it doesn't have an AV audio coming into the same AV channel
Jun 05, 2008 | Computers & Internet
Rabbit ears,vcr,dvr,tv
Connect Rabbit ear antenna to VCR, Take Audio / Video Out and connect to DVR, and Audio / Video out of DVR to AV IN of TV. Start Tuning Channels using the Tuner of the VCR, and store them. Now, whenever you wish to record a particular Channel, select that channel on your VCR, and Record on your Blank DVD in the DVR.
Jan 10, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Top Pelco Televison & Video Experts
Marvin
Marvin
Are you a Pelco Televison and Video Expert? Answer questions, earn points and help others
