Question about Toshiba 50H82 50" Rear Projection Television
Red gun gone...
Hi Guys ( and gals... don't want to stereo type ;-):   I have a friend with this toshiba model.... issue: in the picture there is a red horizontal line.  How easy is this fix?  Were poor solder joints an issue on these like the ones that plagued the older Pioneers?(too easy a fix )  IC replacement no doubt... Would you have a part number?
Thanks in advance for your attention to this request...
Cheers. . . Werner
  • 1,694 Answers
STK392-110T X 2 in TOSHIBA , Do not use generics.If you
want to upgrade = STK394-160E = I use Hitachi brand......T.
Posted on Nov 25, 2007
Have gone from a good picture to green and blue picture.what happened?
If you are connecting the unit by componet cables (RED,GREEN<BLUE) check the cables first to make sure all are connected. If you find they are ok then your red tube may not be lighting up. If you are using a cable box try connectioning the set direct to the cable outlet on your wall. You could also be missing red drive signal to the CRT, in which case service is needed.
Mar 10, 2011 | Samsung Televison & Video
A friend bumped into my Toshiba 61HX70. Now the
Convergence is off. A tech can help resolve the issue.
May 27, 2010 | Toshiba 61HX70 61" Rear Projection...
Loud pop sound now no picture or sound error message and flashing red light
Very likely the bulb has gone they have had some issues with bulbs going quite frequently on this model, bulb I believe is about £100 and an easy job on this model
Nov 27, 2009 | Toshiba 57HM167 57" HDTV
Green picture only
The projection TV has 3 guns RED GREEN BLUE. In your case the red and the blue guns are gone. So you are getting the green color screen. You got to replace the picture tube.
Jul 25, 2009 | RCA TruFlat 27F520T 27" TV
Too much red in picture unable to get it out
The most common cause is the emission of the CRT electron guns are decreasing. They are going out of range and of proper balance in relation to each other for the AKG (Automatic Cathode [K] Gain) circuits in the CRT drive circuits to compensate for proper colour balance and colour tracking.
A less frequent cause are components going defective in the CRT bias and drive circuits.
I would be considering a new TV set with this type of fault condition. The cost of servicing this would be expensive.
Jerry G.
May 15, 2009 | Toshiba 36A42 36" TV
Fix my line problem but red LED flashes five times
Hi Guys, Looks like your advise took care of the problem. I adjusted the power knobs for each of the RGB guns on my Sony 51 inch projection TV. The color looks great and I don't seem to have the blinking indicator light bugging me any more. I will be sure to suggest you folks to anyone with these type of technical questions.
Jan 27, 2009 | Sony KP-51HW40 51" Rear Projection...
Greenish picture, or lack of red.
Not tuner........Did you check RGB screen adjust up front
behind access panel?.....Possible CRT issue.............T.
Nov 27, 2007 | Sony KP-46WT510 46" Rear Projection HDTV
Touch Screen Error
RED GUN OK, you need convergence IC's replaced = Toshiba
part # STK392-110T.....................................T.
Nov 14, 2007 | Toshiba 50H82 50" Rear Projection...
Sylvania 27 inch stereo flat screen tv
This problem sounds like a short inside the picture tube itself unless a driver transistor failed that drives the red gun in the CRT. You may have to take it to an authorized repair facility if the picture tube is still in warranty.
Nov 10, 2007 | Sylvania 6427FF TV
Toshiba 32A41 TV -- color problem
Toshibas are notorious for developing shorts in the inernal guns of the picture tube. In your case the green gun is shorted to G1. The noise you heard was an internal arc between the elements. It is unfortunate however, the repair of this problem usually requires the picture tube to be replaced. Sometimes a savvy technician with sencore picture tube rejuvenator can remove the short. This however usually does not last. Scrivitron
Jun 16, 2007 | Toshiba 32A41 32" TV
Toshiba 50H82 50" Rear Projection Television Logo
51 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
