Question about Cell Phones
Phone won't read micro sd card
I bought a LG ax8600 phone and a sandisk micro sd card. I put some music on the card from my kids windows media . I put the card in the phone and it says there is no music on the card. The phone says there is a card, but it won't read it?
3 Suggested Answers
SOURCE: I have a LG enV2.
ah i just bought one too, to put you music on it put the micro SD into the phone 1st then into your computer,open to see files and put music on it and then drag into the music folder that should work
Posted on May 18, 2008
SOURCE: My LG Chocolate VX8550 wont recognize micro sd card
Here are the steps I took:
  1. Insert the micro sd card with the metal plates facing you (that took me a second). Don't worry about the little push you have to give.
  2. Go to the Settings & Tools option in the Menu.
  3. Select *. Memory
  4. Selct 3. Card Memory
  5. Select Options while the bar is on "1. Memory Usage". The only option available to me was 1. Format and select that.
  6. It will ask for the phone lock code-if you have never set it IT IS THE LAST 4 DIGITS OF YOUR TELEPHONE NUMBER.
  7. The phone will format the card and put the file folders on it.
  8. Use the adaptor USB reader or whatever you have to connect it to the computer. Copy songs to the my_music folder.
for mp3 as ringtones:
  1. You should select the part of the song you like, and can add effects with this:
  2. To set it as a ringtone, send it as an attachments to you It must be small to go through, around 30 seconds.
  3. You will get a text message, and select options. Select Save As Ringtone.
Posted on Oct 17, 2008
  • 450 Answers
SOURCE: My phone won't read my micro sd card.
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Posted on May 12, 2010
0 characters
1 Points
Having problems playing music frommy sandisk 4gb micro memory card on my motorola ve240 cell phone
I have a similar problem, the issue for me was windows media player was creating a folder called music on my sd card and uploading the music there during sync function. However, the phone only looks in the \my_music folder on the SD card. Sync your phone, then rename the newly created music folder to my_music and the player will work. Still looking for a permanent solution to this problem.
Apr 27, 2009 | Motorola Mobility MOTORAZR VE20 Cell Phone
LG KC550 PC Suite Problem
I speant Hours swearing at my phone because it would not read my music files, Tried the card on many different phones which would take Micro SD and all other phones read the music Just not the LG KC550.
I found that getting a Micro SD dongle reader, Insterting your 2GB Micro sd card in that and then putting your music files into the "sounds" folder works.
1. Insert Micro SD card into Card reader.
2. Insert card Reader to Computer Via USB.
3. Go to my computer and Open the USB Card reader.
4. Select the Music files from your pc Via Copy files
5. Go to open Tab (Where you can see your Micro Sd card) Open the sounds folder and Paste.
If you are finding it hard to get the 5 folders of images, Documents, Sounds, others and Videos on your Micro SD card. Format the card by going My computer, Right click the Card reader (with you Micro sd card inserted) and click format. Takes a few seconds. Insert the card into the phone, the phone will auto put the folders on the card. Then go to step 1 (above) and start again.
Hope this Helps guys.
Apr 04, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
LG KC550
kk to add music make sure you syn the phone and the cp do the data and all then put .mp3 on all the media files and see if it works. Then if that doesnt go to computor format the card and then put it in the phone. Otherwise you need new stuff.
Mar 13, 2009 | LG KC550 Triband GSM 5MP Camera MP3 Phone...
Lg kp 500 wont recognise sandisk micro sd!!! aghhhhh!!!
Some memory card wont be recognized by some phones or pc's. I also bought a sandisk card before and just found out (through reading online forums) that some don't actually work.
Feb 22, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Where do you put the sandisk into?
the micro SD(smallest) goes into the phone the other 2 are adapters, mini for older PDA's, the largest goes into your PC (usually on newer models), if the pc does not have a slot for the sd, use a usb adapter to transfer music
Feb 14, 2009 | LG RUMOR Cellular Phone
I have a LG enV2. I bought a micro SD card so I could put my own music on my phone. For the life of me I cannot figure out how to get the music on my phone from the media card. Is there a way?
Ok, format your micro sd card, and then put it in your phone, and mess around in your music, then put it back in your pc and put your music in the media or the music file.. dont remember which one it was, and then put it in your phone. Now you can open your music and it will find them! Enjoy!
May 16, 2008 | Cell Phones
Lg cu500
1 GB max for this phone and you must us a sandisk brand micro sd card it is not compatible with any-other card. Yes, it will work for a little while but you with have problems eventually. I replaced mine with a sandisk micro sd card and I have had no more issues.
Mar 16, 2008 | LG CU500 Cellular Phone
Micro SD card wont work
type 277634# * # (no spaces)
click port setting
click mass storage
click mass storage remove
go back to main screen and check again for memory
if this doesnt work,take out memory card and try without the memory card.
Nov 01, 2007 | LG CU500 Cellular Phone
Saving music on my micro sd..
why cant i get my micro sd to show on my phone
Oct 26, 2007 | LG CHOCOLATE VX8500 Cellular Phone
LG CU500 not recognizing Micro SD card
what is the size of the card you are putting there? before go at hw you must try and see if the size of the card is supported. in some Mobile phones if is larger than supported there will be error in reading
Aug 25, 2007 | LG CU500 Cellular Phone
Cell Phones Logo
711 people viewed this question
Top Cell Phones Experts
IT Solution
IT Solution
Are you a Cell Phone Expert? Answer questions, earn points and help others
