FixYa.com
Tags:
Panasonic PanaFax UF-490 All-In-One Laser Printer
Printer Code and Power Failure Error
posted by kgosa on Oct 29, 2007
We had a power outage at work over the weekend.
The power is back on but the Panafax UF-490 will not print any faxes. There are two error codes that flash "Printer Error 021" and "Power Failure 887".
I have tried unplugging it for a few minutes then plugging it back in, in other outlets.  I have also replaced all the cords, etc but it's still not working.
We have no tech support and we have no service contract with anyone for this fax machine.
We are able to fax out, however, and we are receiving faxes and they are being stored in the memory, they just aren't printing.
HELP !
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on Mar 12, 2008
FixYa! (100)
PeterLunde
Rank:Apprentice Apprentice
Rating: 100%, 1 votes
I had to do:
[Function] 7 [monitor] (4 times) *
(service mode appears)
7
(SET LBP PARAM appears)
[Set]
[down arrow]
(LBP FUSER RESET appears)
[Set]
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Mar 17, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
Rubbish fax machine.
Get a new one!
Solution #3
posted on Jan 30, 2008
Not Rated (0)
mj0147
Rank:Master Master
Rating: 88%, 11 votes
the machine memory is hung
try this
press Function 7 monitor(4 times) *
service mode is appear
scroll down.. select Ram initialize select all job clear.. if the problem still there.. repeat the procedure but instead of all job clear.. select the Flash memory clear.. found it after all job clear mode
Can you Help with these Printers problems?
Panasonic PanaFax UF-490 All-In-One Laser...
Panasonic kx-fm386 problem
Hi, I have a problem with... Answer This...
Two problems with fax machine
How can I get a print out every... Answer This...
Printer err
Our fax says printer err 021, I... Answer This...
reset fuser but the display...
Panafax UF-490, I reset the... Answer This...
Hi I have lost the CD for... Answer This...
Repair Service
Find Printer Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
