Question about Weber Genesis Silver B Grill
My grill won't light, and I don't hear gas running
I have a full tank of propane (gas), when I turn the first ignition on I hear no gas running. I have looked underneath the control and it seems to go down to turn the valve on. The starter makes the same striking sound it always has, and even a lit match does not work. Previously, due to a mistake, someone I believed to familiar with the grill left the previous propane tank screwed ALL the way open. I started it briefly last Sunday, and it went out almost immediately. I have since cleaned the inside of the grill, but have been nervous about taking the gas portions of the grill apart (with the propane detached of course). Any ideas?
  • 3 Answers
I had the same problem with my grill once last year and again this year. I installed the tank on my son's grill and it worked perfectly. Try replacing the regulator, it worked for me.
Posted on Jun 24, 2009
    President:
  • 512 Answers
Sounds like a problem with tank valve. Try attaching back to grill. Open valve slowly, if you open to fast valve thinks it is leaking and shuts down. If this doesnt work try a differant tank, buy always open slowly.
Posted on Jun 13, 2009
I have had to replace the hose and regulator twice in the 10 years I have had my Weber grill. If you can't hear the gas flow, it is not getting through the regulator. New hose and regulator can't be purchased at Lowe's, etc for about $20.00. Make sure you take old one with so you get the same fittings on both sides of the hose.
Posted on Jul 06, 2009
Weber grill will not light
you have to narrow down the problem.when you turn the propane on first at the tank (make sure lid is OPEN) and then turn on the burner control are you smelling gas ? If yes then its simply ignition (BBQ lighter to light manually) if no smell are you sure there is propane in the tank ? Can still feel like fuel inside when empty.if you smell gas but won t light check your venturi valves for spider nests,etc if it sat outside for the winter.it will stop the propane from coming thru the burner.Good luck (my money would be no fuel ) please let me know !
May 05, 2018 | Weber Grilling
Why won't my Weber grill ignite after installing a
Disclaimer- be careful when working with gas. Starters in gas grills are just about novelty anymore. Often, they only light 1/3rd or 1/4th of the burners and they usually stop working within one grilling season. I recommend using a wand lighter. Try to light just one burner but if doesn't light in 5 to 7 seconds, turn the gas off and wait to try again. Incidentally, you are turning the gas on at the tank, right? You should hear it when you turn the burner on.
Apr 24, 2012 | Grilling
I have a Weber gas grill, and I just replaced the propane tank, yet when I ignite it on the Start/High setting, very little flame is produced. This is the first time in 5 years or so that I've...
Don't worry, you'll be grilling in no time, if you follow these instructions:
1. Turn the gas tank valve OFF.
2. Disconnect the grill's hose from the propane tank and wait 5 minutes.
3. Reconnect the hose to the tank and open the tank's gas valve VERY, VERY SLOWLY (Slow Motion, slow).
Once the valve is fully open light one burner and turn it to HIGH. Has the flame height returned to normal? If so, light the remaining burner and turn it to HIGH. Do both flame heights look normal?
If so, you solve the problem! Remember to always turn the tank valve ON Very, Very Slowly.
Hope this helped you. Please let me know and Happy Grilling!!
Jun 16, 2011 | Weber Baby Q Grill
I'm trying to start grill, it has a full propane tank , it ignites then it turns off
You might have a bad propane tank. If the tank is new take it back and tell them you think the valve is bad. They should exchange it free of charge. Sometimes the valves on the tanks go bad, then they just don't get very much gas and can easily shut off.
Jun 06, 2011 | Weber Genesis E-310 Gas Grill
Brinkman gas grill won't start. Don't hear clicking sound. Hooked up new gas tank, but no success
Victor, are you sure you're getting gas to the burners after installing the new tank? You can try match lighting them to make sure. But, I suspect, that it's the installation of the new tank, that's causing the problem.
To test my theory, tune the tank valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Ope the tank valve VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, try lighting the burner that's farthest from the tank first and turn it to high. Did the burner light and does the flame height look correct? If so, light the remaining 3 main burners the same way. Did those burners light and the flame heights looks correct? If, so you solved the problem. Remember to always turn the tank valve ON VERY, VERY SLOWLY.
Hope this helped you solve the problem. Happy Grilling.
Jun 01, 2011 | Brinkmann 810-8410-S Stainless Steel...
Need to know how to reset the LP Gas flow for a Webber 300 BBQ
If you just installed a new, full tank of propane and turned it on and the burners wouldn't light.
Turn the tank off, disconnect from the grill hose (you'l hear a whooshing sound and smell gas, but that's alright). Wait several minutes and reconnect the hose to the tank. Turn the gas valve on very very slowly, until it's full open. Now, try lighting your grill.
Remember, you will need to turn the tank valve on very very slowly every time you change tanks or turn the tank off after grilling.
What happened was this ... When you turned the tank on quickly it locked up the grill's gas regulator. Doing what suggested usually solves the problem. Oh, one other thing ... be sure your tank is not empty. The grill you have uses a lot of gas.
Feb 02, 2011 | Weber Grilling
Grill does not get hot. I have a fresh bottle of propane. Hose is not kinked. Grill is maybe 6 - 10 years old.
hi,
When a new or newly filled propane tank is attached to your gas grill, the OPD is usually at its maximum limit position above a tank filled to capacity. Propane may come through the valve too strongly due to the additional pressure of being full and the OPD displacement. The propane tank goes into check and limits gas flow when too much pressure hits the valve. Some grill manufacturers provide instructions for this in the users manuals but most people do not read the manual. Many grillers believe replacement parts are needed and burners, ignitors and regulators get replaced without reason. Depending on how efficient the grill is operating, some grills attached to a tank in check will not ignite and others will light but cannot reach cooking temperatures because the tank has limited the amount of propane released. Sometimes the food will be unable to exceed 200 degrees in temperature because the propane tank is in check.
Gas grill replacement parts are available and are sometimes necessary, low or no gas flow indicates a different typr of repair. Most grillers accept instructions and the problem is corrected in minutes -- but believe it or not I have had a few insist on purchasing replacement parts.
How do I fix grill?
To reset the check valve and get back to cooking on your gas barbecue grill, first
turn everything off. Turn off the grill, the rotisserie, the side burner and the LP gas cylinder tank. Once everything is turned off disconnect the propane tank from the gas grill regulator by unscrewing it or pulling the quick-release on older or retro-fitted propane cylinders. Now turn the grill on. I know, it is dis-connected from the gas tank but we want to ensure that the pressure in the gas lines or any gas in the burners is released. Leave all grill burners in the on position for 3 - 5 minutes before turning them off. Make sure. Most gas grill valves must be pushed in to turn them and if turning is attempted without pushing the knob, they will not turn to the "on" position. With the grill, et al turned off reconnect the propane tank and slowly turn the hand wheel to the open position.
Slowly. The trick here is to turn the hand wheel slowly. Propane in a new or very full tank will be under more pressure, especially with the OPD floating in position. The extra pressure will come through the tank valve stronger. Turn the gas tank slowly allowing small increments of propane to enter the grill.
Once this is complete, you should be able to turn the grill on high and ignite your gas grill burner. Your cooking heat should be back to normal and cooking times decreased. If the problem persists, try this process again to make sure you followed every step. The check valve exists to save your life if there is a leak in any of the gas fittings. Constant check valve issues could imply a gas leak and a visit from your local gas grill service technician may be necessary.
To find a leak, turn the grill valves to the off position and the gas tank valve to the full on position. This should pressurize the gas line. Spray soapy water on all the fittings and look for bubbles just like checking for the leak in a flat tire.
Do not attempt to correct a gas leak on your own. While a check valve error when your gas grill will not get hot or will not ignite is a user education error and an issue corrected by learning about your propane tank, a gas leak should be corrected by a licensed gas service technician. When you are grilling, turn the propane tank on first and then turn on your grill. When you are done cooking, turn the gas tank off first and then turn off the grill valves. The process releases the pressure in the gas grill hose and manifold which allows the gas tank to release pressure by filling these lines. Read the safety features of your gas grill, clean it when necessary and replace used and failing parts. Aside from that be safe, eat well and have fun.
thanks.
Jun 15, 2010 | Weber Genesis Silver B Grill
Grill will not ignite even with manually trying
Can you hear or small gas? It's possible to may have turned the propane tank valve on too fast. Close the tank valve, disconnect it, then reconnect it. Slowly turn the tank valve back on and try lighting it again. Hopefully this is your solution, but let us know if you need more assistance. Or check out my Tips & Tricks for gas grill lighting problems, just click on my user name and scroll down to my Tips & Tricks and see if any of those solutions help.
Douglas
Jun 04, 2010 | Weber Summit Platinum C4 (LP) Grill
Can't light the bbq
You make have turned the propane tank valve on too fast. Close the valve, disconnect it, reconnect it and very slowly turn the tank valve back on. That should solve your problem.
May 31, 2010 | Weber Genesis E-310 Gas Grill
How do i light this gas grill, it is a charbroil quantum....it was borrowed from our friend, who is now not picking up the phone...
Checklist:
1-Make sure propane tank has propane in it.
2-Turn regulator (valve attached to propane tank) on.
3-Turn burner dials on, usually there is a "light" or "ignite" position to let the most gas flow to start. If there isn't, just turn it/them to high.
4-Listen for the hissing, if you hear some hissing from the grill, it has gas flow.
5-Turn the dials back off and give 3-5 minutes for gas to clear.
6-Turn dials back on and hit the igniter button.
That should do it! :)
Sep 22, 2009 | Grilling
Weber Genesis Silver B Grill Logo
12,188 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Marvin
Marvin
Are you a Weber Grilling Expert? Answer questions, earn points and help others
