Question about Car Audio & Video
CAR WIRING I have a golf II which i wrote off. two days after the accident a friend kicked the car,, sparks came out! so i disconnected the battery and pulled the motor out. the car went for repairs and got it back in whole condition. ive now put the motor in and done the connections using a mates car as a diagram.. so i swing the key and the little red lights show, GREAT.. then i swing it some more,, and the motor turns!! GREAT!!! with that done its time to connect the pipes, so i go to turn it off and the bloody thing wont stop- starting. i disconnect the battery and try again, no movment, so i swing the key again, and again it wont stop till i disconnect and connect the battery.. i noticed the earth wire going to the motor from the battery gets smoking hot while its doing this horrible manouver.... is there anyone who can assist me with how to go about this PLEASE PEOPLE!!!
  • 328 Answers
Make sure that the starter wires are secure and in the right place first. It could also be a sticking solenoid. I suspect a wire not connected to the starter. Let me know if it works so I can help you more.
Posted on Oct 29, 2007
Need help putting new batteries in 1980 club car can't figure out how to connect wiring to new batteries
This should solve your problem.
Next time you want to take something apart, be sure to take a picture or 2, before you disconnect anything. That will help you put it back like it was.
Jun 16, 2017 | Cars & Trucks
When I connect the battery the blinkers come on constantly glowing, nothing else works, check the fuses, the alternator fuse is blown, replace that, connect the battery fuse blows again. 2007 solara.
Bad alternator or short in alternator wiring. You much need a wiring diagram. Is that the car? Was in an accident? You may have pinched wiring or a wire shorted to ground. Try new fuse with alternator disconnected, then with key on, connect alternator-watch for sparks, or clicks, -you might want to have the alternator tested, just to be sure. You have to start somewhere...
Maybe a wiring short in the blinker system? Or is the fuse blowing an alternator fuse?
Oct 23, 2016 | 2007 Toyota Solara
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
Jan 24, 2016 | Golf
go to any national chain parts store and they will pull the code for you-I'd guess based on what you wrote that it is a crank or cam sensor, or a bad ignition module.
Apr 07, 2014 | Ford Focus Cars & Trucks
2001 VW GOLF. battery draining over night, a friend of mine who's a mecanic put a light tester to the battery and checked all the fuses no leak there, disconnected the glove compart light switch...
Hi there?
You need to test the battery itself. It could be faulty battery. Some batteries have a little LED bult in them, green led good battery, amber led battery needs charging, red led battery needs replacing.
You could allways disconnect the battery after the use of the car. if the battery still goes flat then you need to replace that battery.
May 22, 2011 | 2001 Volkswagen Golf
Can removing the battery terminals with the key still in the ignition be responsible for damaging the wiring system of my VRG6 golf? This has lead to damage of the coil to the spark plugs.
In a word.....NO
My daughter has a Jetta..... electrical problems are common in these cars.... remove the key, let the car sit for an hour with the battery disconnected.... connect the battery, turn the key to the run position but DON'T start the engine...... let it sit like that for about 2 minutes.... if there are no issues with the car, is should start right up and run fine after that
Oct 14, 2010 | 1996 Volkswagen Golf
2001 volkswagen golf epc light on loss of power
i had the same problem... Change the spark plugs and the ignition coils, All of them... It usually accelerates without giving it gas.. Don't worry about that...
Jul 02, 2009 | 2001 Volkswagen Golf
Battery problems
is the earth on your battery lead connected and properly earthed ? it may have been damaged in the accident and overlooked this could be causing your current problem
Jun 29, 2008 | 2000 Volkswagen Golf
Car Audio & Video Logo
238 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
