What is the exact error message that you are getting. It could be many thing. your laptop might have overheated and fried something in the computer, or your harddrive got corrupted or it failed. What is the exact error message that you are getting. It could be many thing. your laptop might have overheated and fried something in the computer, or your harddrive got corrupted or it failed.
You can't post conmments that contain an email address.
have you made any changes before the blue screen appear? installing a driver maybe? if you have,try to undone those changes by booting with Startup with last known good configuration (undo recent registry and driver change),use System Restore,or Roll Back device driver,Scan your computer for viruses and Return BIOS settings to their default levels,go to BIOS by pressing F2 or del exactly after you press the power button and the screen show up if it still in blue screen,that's probably that some of your system file is missing,and you need to reinstall your operating system Please let me know if it's working or not,i don't like to abandon anyone,and thanks for using fixya
-try t drain everything out of the computer first; remove the power adapter then remove the battery; after 1 minute try again; if problem persists run diagnostics
--while the computer is off, press and hld the "Fn" key then press the power button at the same time to start the test; note down error message then consult manufacturer for the code obtained. if no errors found it is a windows problem; you need to reinstall windows on the computer
Try tapping the F5 or F8 key (could be either one) right after you power up.
This should take you to a short text message with a couple of choices to continue; you'll find the Safe Mode option there.
windows are corupted somebody has forced ur computer to shutdown manually u need to repair ur windows first by the windows cd or needs to perform clean installation
