Question about Hotpoint HSS25GFP Side by Side Refrigerator
Water under side by side hotpoint
The ice maker & water line are both disconnected.  there is an ice "block" on the bottom of the freezer & every couple of days, I have been finding puddle of water underneath the unit.
  • 4,889 Answers
You can deal with it once for all by pouring warm water into the drain pipe to clear any blocks and sopping it off with a sponge..
Posted on Oct 29, 2007
  • eagle338
    eagle338 Oct 29, 2007
    You have to keep doing it until the water can enter from one side of it and comes out frm the other..
Hsm25gfra sa. Bought used, was told ice maker didn't work, so haven't hooked any of that up. Problem: water/ice is pooling in the bottom of the freezer section. Every day or two it leaks out. I'm...
The refrigerator has a blocked condensate drain line. In most Hotpoint models it is easily accesed by pulling out the bin at the bottom. There should be a drain grommet at the center of a trough in back. This plugs up. You may have to pour hot water the thaw out the ice and then either blow out the drain tube or I use a 5/15 plastic hose and push it through the drsin to clear it out. this should fix the problen for a long time. Food particles etc. collect in the drain and ice forms around them and blocks the drain.
May 17, 2014 | Hotpoint HSS25GFP Side by Side...
I have a Hotpoint HSS25GFTA WW Fridge that has side by side doors with ice/water dispenser in the freezer (L) door. I still get ice fine but my water dispenser has 'died'. The water has always come out tap...
Hello:
It is very common to have the line in the freezer door freeze up. I would start there first. If that's not it then next step would be your water valve which is located in the back/bottom of the fridge. It is a dual valve( one side for ice maker the other for water dispenser). you can check that by taking off the front kick plate and on the bottom freezer door hinge you will see the line entering the door. Follow it towards the under the fridge and you will find a coupling. Disconnect it and see if there is any water coming out when you press actuator on the door .. If yes then its frozen if no your valve is Kaput.
Cheers
Jun 10, 2017 | Hotpoint HSS25GFP Side by Side...
My maytag frig with the freezer on the bottom has suddenly stopped making ice. There is nothing blocking the arm in the ice maker and I can hear it making the sounds it makes when it makes ice but no water...
Good day,
Just follow this step by step proceedure. It'll get you there.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
Mar 08, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Water on floor under freezer side csx20ea model hotpoint sems like twice a day a puddle the size of a cereal bowl is under front left hand side of my side by side fridg i have a pergo hard wood floor im...
If you have an ice maker, check for a leak in the water line. If no ice maker, there could be a leak in the pan for the defrost water, or the drain hose is out of position. Also, check to see if the water is actually leaking out from the freezer door. That would indicate a clogged drain. The bottom inside the freezer may have water, or ice on it. If so, suspect the clogged drain.
Jan 06, 2010 | Refrigerators
Just hooked up the water line to my hotpoint side by side. There is no water running to the ice maker. The switch is on in the freezer. Is there something else to check?
Did you install the water filter. If you have, possibly it needs replacement. (blocked). Water has to run through filter first.
Nov 11, 2009 | Hotpoint HSS25GFP Side by Side...
No water
I HAD THE SAME PROBLEM. 1ST LOOK AT THE BACK OF YOUR FRIDGE. MAKE SURE THAT THE VENTS ARE CLEAR OF HAIR AND DEBRIS. YOU MAY NEED TO REMOVE THE BACK PLATE AND VACUME THE DUST FROM THE COMPRESSOR MOTOR. IF IT CAN NOT BREATHE PROPERLY IT WILL WORK HARDER AND HARDER CAUSING THE FREEZER TO BECOME TOO COLD AND WILL FREEZE THE WATER LINE THAT GOES TO THE DOOR. AFTER THE BACK IS CLEAN LOOK UNDER THE FRONT OF THE FRIDGE AND FIND THE WATER LINE TO THE FREEZER DOOR. TAKE THE CONNECTOR LOOSE ON THE SIDE CLOSE TO THE DOOR AND PRESS THE WATER BUTTON. IF WATER SQUIRTS OUT THEN THE LINE IS PROBABLY BLOCKED WITH ICE. RE-CONNECT THE WATER LINE AND UNPLUG YOUR FRIDGE. YOU WILL NEED TO LET IT DEFROST AND THE WATER SHOULD WORK AGAIN. YOU CAN SHINE A FLOOD LIGHT ON THE FREEZER DOOR TO WARM IT UP AND SPEED UP THE THAWING PROSCESS. IT ONLY TOOK ME ABOUT 20 MINUTES.
Jan 12, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Ice maker not making ice. Water disp inside frig disp water.
the line that gives water to the ice maker, every time the water comes down it lives a drip of water that turns to ice blocking the line, get some hot water and a towel and place the hot wet towel on top of the line intel it melts the ice in side the line. it happens to my frige at list once a year. if that is not the problem the valve that supplies water tho the ice maker needs replacing, it's behind the frige at the bottom, where the line coming from the house meets the frige.
Dec 10, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice maker
disconnect the power wires from the valve, if it still fills with water, I would say you have a stuck valve. just because its new, doesnt mean its going to work.
Sep 30, 2008 | Hotpoint (HSM25IFTSA) Side by Side...
Hotpoint Side by Side leak and cooling issue
fault is poss that drain for defrost water is blocked and this can cause both faults. remove back cover of freezer and check if ice build up. if so melt of with hairdryer and make sure drain is also free of ice
Feb 15, 2007 | Hotpoint HSS25GFP Side by Side...
Hotpoint HSS25GFP Side by Side Refrigerator Logo
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
