Home | Sony | KP-46WT510 46 in. Rear Projection HDTV Tel... | Replaced STK's, fus...
Sony KP-46WT510 46 in. Rear Projection HDTV Television
Problem for Sony KP-46WT510 46 in. Rear Projection HDTV Television
Replaced STK's, fuses ok, +/- 22 VDC ok, still can
By pchorney on Jun 12, 2009
Sont KP-46WT510 will not converge. Replaced STK's, fuses ok, +/- 22 VDC ok, still can not move any convergence points in manual?? LED blinks 5 times??
Solution #1
posted on Jun 13, 2009
Not Rated)
Slinteriors
Rank: Guru  Sony Expert Televisions & Videos  Expert
Rating: 89%, 3635 votes
did you checke the two 5amp IC protectors located on the G board? Those will usually blow when the original ICs fail.
Was this helpful?
Yes
No
Popular Solutions for Sony KP-46WT510 46 in. Rear
Questions and Unsolved Problems for Sony KP-46WT510 46 in. Rear
Do you recommend Sony KP-46WT510 46 in. Rear Projection HDTV Television?
Answer
Answer
Our picture is visible but is in blue tint. How much is that to fix, around? Is there anything... (More)
Answer
red light bye the power bouton but no pictuer
Answer
TV will turn on but no picture shuts off and red light flashes next to power button
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony KP-46WT510 46 in. Rear...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
