During the recording, two "water-streams" (blurred vertical lines) appeared on the left and right of the screen. Unfortunately they appear on the final version of the video as well. As an audio recorder was used a separate device - zoom h4n, which was mounted on top of the camera. Is there a possibility of interference between the devices, or it might be a pure encoding/lense problem?
SOURCE: Not able to record the image
I had the same problem. Called Canon tech support @ 1-800-828-4040. Was told it is a problem caused by a chip going bad, and that Canon will repair my camcorder free of charge. They send you a couple of emails. You fill out the form, mail your camcorder off for the repair. You should get your ZR85 camera back in about two weeks.
SOURCE: VIDEO CAMERA SHOW BLURRED LINES WHEN PLAYBACK VIDEOS
sir!
Clean the lence cover of your camera it might sovle your problem.
SOURCE: blue lines appear across screen during video playback.
thank you for choosing Fixya.com.
it seems that some parts in your Cam are Dirty.
please try to use the head cleaner disk first.
let me know if any changes happen.
goodluck
please don't forget to rate our answers properly.
SOURCE: i can't watch any video in any recorded tape,
it happen to me once with a sony camcorder I used to own , you need to reach the VIDEO DRUM HEAD , with a Qtip moistened in a video head cleaner , go directly to the tiny slots and gently rub to remove excesive oxide acumulated that a tape cleaner cant reach, wait a couple minutes so the video head can dry before playing a tape , good luck AJ
