Poor signal strength
I have a wireless network at home but with my new acer lap top when i log on the signal strength drops to 2 bars (very poor signal). however if i log of and look at the signal it is full bars until i log on then it drops again. any freinds who have brought there pc to my house this doesn't happen. they get the full strength signal. what can be done to fix this? i have checked with the router people and they say it is a pc problem.
  • kurobara Dec 02, 2007
    I have the exact same problem. I have tried changing the channel on the router. I have even tried using a different router, and still I have the same problem. I continue to get a poor wireless connection even though when I log off, it shows that I have a full strength connection. Any suggestions?
  • 20 Answers
Have a go at changing the wireless channel within your router there may be some interfearence generated by your pc that is affecting its signal strength
Posted on Oct 29, 2007
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Restar
If by resetting you mean the wireless connection keeps dropping and reestablishing then you must likely have poor signal strength to the wireless router. The strength of the wireless signal can be greatly diminished by walls and other objects in the way of the wireless router. Best advice if your fairly close (less than 20 ft) from the router would be to invest in a wireless N router, you will get a much better signal.
Feb 03, 2012 | Computers & Internet
I have a Belkin wireless router connected to a Virgin modem. Always has worked fine with a Compaq laptop and 2 Dell Inspiron netbooks with excellent signal. Now have tried to connect with an Acer Revo rl...
The router is designed in such a that it is compatible with all the computers. The best way to get rid of this issue is log into the router interface and change the wireless channel to suit your requirement.
1) To begin with.. Open internet explorer on a computer connected to the router and delete everything from the address bar and type http://192.168.2.1 and hit enter. Now you will be in the Belkin Router setup. It will ask for a login password when you click on anything.. Leave the password field blank and click on submit. 2) Towards the left side under wireless click on "Channel and SSID". Now you see wireless channel change it to different channel and click on "OK / Save". Now check the signal strength in your Acer computer. If its still the same try different channel and check.
Hope this helped.
Feb 22, 2011 | Computers & Internet
The County Sheriff broke my door down while I was not home. Left a John Doe Search Warrant on the table. They tore my house apart but didn't take anything. Mine and kids' Laptops were with us, but now we...
> can't access 'net through router
When you "view available networks" on your laptop, do you see the SSID for your router as being present? What's the "signal strength" (poor? none?)
Have you tried powering-off the router, waiting a few seconds, and then powering-on the router, and then retrying on the laptops?
Have you tried an Ethernet cable directly between the network-port on your laptop and one of the LAN ports on the router? That should give you a fast connection, because it is not "wireless".
> cell phones all drop calls
Weird. Did they wrap your entire house in metallic foil, to "block" signals from the cell-phone tower to reach inside your house, to your phones?
If not, why has the signal-strength dropped so much?
What happens if you take your cell phone just outside your home? a few houses away? a few blocks away? a few miles away? Does the signal-strength increase "sharply" at some distance?
With your cell-phone, walk all the way around the outside of your house, to see if there is a "good" side or a "bad" side. Repeat on the inside, and see if you can draw a "map" (4 bars here, 1 bar there).
Apr 09, 2010 | Computers & Internet
Wirless signal strength fades
it sound like to me that someone is logging on to your router set up your laptop with wep or wap with 128 bit enycription and let me know how that works
Mar 17, 2009 | Toshiba Satellite A105 Notebook
Bought a compaq 6710b. The wireless connection stability is very poor. I can find my wireless network at home on Vista platform, but the connection drops out after several seconds and is not able to find...
Hi there
if you are seeing the network and are able to connect to it but it is getting dropped normally this wouyld lead to the signal not being that strong you can try to move the computer it doesnt take tot much to change the signal strength and see if the signal get' s better it should tell you how your signal is ok
Feb 28, 2009 | Computers & Internet
Linksys N router drops signal
Its not dropping you because of the spectrums, it works on line of sight. If you are in a basement and your router is upstairs it has to go thru a floor and the strength is weakened. Go into your router and increase the signal strength. But you have to mod your firmware.
http://www.coderetard.com/2008/05/30/install-dd-wrt-firmware-on-linksys-wrt150n-wrt160n-wireless-routers/
Here is a link to update your firmware.
Jan 24, 2009 | Linksys Wireless-N WRT150N Router
Wireless-g wusb54gs
i like a cd for my wireless 2.4 ghz 802.11b
Jan 28, 2008 | Linksys Wireless-G WUSB54GS 802.11g/b
Computers & Internet Logo
455 people viewed this question
Alun Cox
David Payne
David Payne
