Question about GE Profile JTP56 Electric Double Oven
Ge wall oven blinking door locked for days
I cleaned the oven with the self clean option and the blinking continues.  I can get the door open with the lock and unlock buttons but the oven wont turn on.  just saies door on the screen and blinks door locked.
  • 9 more comments
  • Bonita3900 Nov 05, 2007
    I was trying to change the time without my glasses on.....and I hit the clean button instead...i saw a 3 on the time but hit cancel.....my door is locked and wont unlock...the self cleaning unit did not come on, just the door locked. How can I unlock it. I have tried cancel over and over and still nothing. Thanks
  • Anonymous Mar 15, 2014
    self cleaning was shut off manually. door lock jambed
  • Anonymous Mar 16, 2014
    ge oven model kebs109bbl00 locked after self cleaning
  • Anonymous Mar 18, 2014
    ran the self cleaning oven and the door won't unlock code foe1
  • Anonymous Mar 23, 2014
    Oven won't work if the self-cleaning is going like keeps blinking cleaning
  • Anonymous Mar 24, 2014
    after turning GE jkp48 oven on it gos to cleaning
    door locked in self clean mode
  • Anonymous Mar 25, 2014
    self clean says lock oven door
    the oven door will not open after the self cleaning is finished
    how do I get the oven door unlocked?
  • Anonymous Mar 30, 2014
    took off to clean and can't get it back on
  • 100 Answers
The switch inside the door lock mechanism is stuck down making the unit think it is still locked.  the switched is located next to the hook that locks your door.
Posted on Oct 31, 2007
My GE wall oven is stuck on lock mode. I cancelled a self clean (I know, big mistake) and after cooling down it still won't unlock. I've cut the power and still nothing. It's been 3 days! Trying to avoid...
Try putting it back in self clean. Listen to see if it locks. then cancel the self clean. It could be the self clean lock motor has gone bad. The lock hook can be moved to unlock the door by inserting a stiff wire like a coat hanger between the door and the oven and moving the latch over to unlock the door.
Nov 07, 2014 | Ovens
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
We have a frigidaire fef354cjsa oven that has a self cleaning option. We started the self clean and it locked the door. 2 days later we cannot open the door still. The lock light is blinking. We have tried...
The best way to do is to pull the oven out if is built in and go through the top. If its free standing use a clothes hanger and make a hook and pull the latch to where youcan open the door. Your going to have to replace the lock motor assembly. Bit of advice though, slef clean is the worst invention ever and if you use it you will have more problems.
Nov 02, 2010 | Frigidaire Ovens
I turned on the cleaning switch for my self cleaning wall oven and now it seems to be finished but mthe door lock is still on and the oven keeps making a buzzing noise what do I do?
If the lock does not open after the oven has cooled down, then try this: First, unplug the range or shut off the circuit breaker for ten minutes. Plug the range back in or turn on the circuit breaker. Set the clock and try moving the door lock lever or opening the door. Next, set the self-clean cycle again and only allow it to work for twenty minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever or opening the door
Mar 13, 2010 | Frigidaire 27 in. Electric Double...
After doing a self clean, the panel now flashes locked
thermal protector has caused lockout. happens w/ self clean a lot. it's a small thermostat device most likely on the rear of the oven. oven need to be pulled from wall to check/replace. you may have to open door w/a coat hanger if it's locked to get the door open to allow access to screws to allow removal of oven from wall if it's a built in. unplug it before doing anything. fuse is under back cover size of a bottle cap, 2 wires, should be "closed" normally. replace or spray w/freon to "reset" it.
May 25, 2009 | GE Profile 30" Built-In Single Electric...
GE Elec oven JT952-30" blinks the "lock" after self-clean
Try unplugging power cord or trip circuit breaker, to cut the power to the appliance, then wait one or towo hours for the oven to cool down completely.
If the door stays locked, then there is a fault, probably a faulty temp probe that had blown because of high temperatures generated on self cleaning, or a defective control assembly. In that case you will need to call a technician to take apart the oven and fix the fault.
Enter model number here to find assembly diagrams and parts.
Jan 02, 2009 | GE Profile JT952 Electric Double Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
Self cleaning won't shut off
that is because it needs to cool down before the oven will unlock.There should be a timer running and when it gets to "zero" it should unlock.
Jul 08, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE Profile JTP56 Electric Double Oven Logo
1,264 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
