Question about RCA D52W19 52" Rear Projection Television
Part number for board.
What is the Part number of the board Located in the left corner of the backside of the television?
  • 3 more comments
  • Ed_Sharpie Oct 29, 2007
    It must be the "Power / Delection with PSB 910 on edge = 265324",
    The board has PSB-810 on the edge. There is a Murata video component that failed on the board. The TV initial failure was a "Pop" followed by a burnt odor. I removed the back panel, and the "Murata" component is burnt. Can this part be replaced alone, or does the whole board need to be purchased?
    Here is the approx location of the part on the board. The manufacturer is "Murata". The service number is E322C10JQ
    There is a sticker on the edge, with what appears to be the part number and serial number.
    PSB-810 CQ13 18614430612059
    "Service number is the same as model # , but three characters longer ......T."
    OK, it looks like the service # is D52W19BYX1
    Underneath that is another sequence of numbers, E322C10JQ
  • Ed_Sharpie Oct 30, 2007
    The Part location is LL008. There is a grid, and the grid location is P6.
    Genius:
  • 1,694 Answers
Not sure of which side, or why you want board #'s-------
 Power / Deflection board = 264102
 Small signal board = 264120R
  Let me know the service # and symptoms to repair PCB.....T.
Posted on Oct 29, 2007
  • 1 more comment
  • Vista Electronics Oct 29, 2007
    What is the location of the part indicated on PCB?
    Also, what is the service number of the tv (off back)??
                Let me know......T.
    Part location meaning-----C403,R543,D778............T.
SOURCE:
I have Philips 49PUS7909 LED smart TV and when i start, only PHILIPS logo is displaying on it. Nothing happens next. Please help.
I did the software-thing aswell, to me it did not work but..
When you remove the backside of the TV, you will find a PCB/board with the powersupply and a PCB with the CPU.remember to remove the interface cable for the ambilight, before you remove the backside of the tv. you gain access to it by removing the shield around the joystik at the down right corner of the backside of the screen
When you have removed the backside of the tv, remove the board with the CPU, remember to remove interface cables so you can turn the board around and look at the backside.
When you look at the backside, you will find 3 massive thermalpads, they might be stucked on the panels backside.
Thermalpads are made by silicone, among others, those pads, might be "sweathing" silicone(or whatever), during long periods of heeattransfer, so take a piece of toiletpaper, and gently remove the sweath/moist from the pad and the board.
Dry the board with a hairdryer after you remove the moist on it and assemble the tv. dont forget the ambilight :)
Let me know how it works.
Sep 10, 2017 | Philips Audio Players & Recorders
IR board location
Hey Tony,
The IR board will be on the inside of either the bottom center, left, or right of the front bezel.
Apr 03, 2013 | Samsung LN46A630 LCD TV
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Feb 08, 2012 | IBM Computers & Internet
52" Sony Bravia TV has a thin Blue line down left
A line on an LCD screen can be cause by the screen itself going bad or the T-con board. The T-con board the attached to the screen on the backside and covered by a heatshield. If you get teh part number from it you can find it online from one of the many retails that might have it. Like www.interliquidparts.com
Jun 06, 2011 | Sony BRAVIA KDL-52XBR4 LCD TV
Where is the ysus board located on a nec plasma sync 42mp2(px-42vm2a) tv.
The board is located on the extreme-right at the center of the chassis. In some sets I have seen the Y-sus on the left and the Z-sus on the right. If you can get me the part number off the board I can confirm if that is the board
May 21, 2011 | NEC PlasmaSync PX-42VM2A Television
No picture no sound, will not repond to controls once turned on
A very common problem w/ this set is a fuse that will open, that is located on the main board(the board w/ the tuner on it). This is a very small surface mounted fuse, it's white in color, and located at the upper right hand corner of the board, if looking at it from the back of the set. The location number is F3 and the fuse is 1.5 amp. I have seen many of these. I would definately start there.
Jul 29, 2010 | Vizio GV47LF Television
Cant change channel and/or input mode, picture is horizontally scrambled?? Philips 55PP970104
Possibly, your small signal board needs replaced! It is usually located on the left side on the backside of the tv. It is inserted into the convergence board. This is a good place to start. Hope this gives you an idea to speak with a TV tech!
Jan 17, 2010 | Philips 55PP9701 55" Rear Projection...
Red double lines left upper corner samsung hcl4715w
Sounds like you need to replace the convergence board or the IC's on the convergence board, to find the board go to partstore.com enter the model number the enter the keyword of convergence board and it should come up. Good Luck.'
Larry Dillon
Aug 15, 2009 | Televison & Video
A customers querie
the number of the ic is ---WC24Y8--- and it is located on the left corner of the main board.thanks.
Aug 22, 2008 | Protron PLTV-37 37 in. LCD Television
Very small problem
If you have the original remote, press display and hopefully the AV6 display will go away.
Jul 15, 2008 | Sony BRAVIA KDL-46V3000 Television
RCA D52W19 52" Rear Projection Television Logo
191 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
