Question about Samsung S850 Digital Camera
SOURCE: camera won't turn on
Plug it into the charger, then remove the battery. Disconnect is and then insert the battery/ That may reset it.
This also sometimes happens when a camera is dropped and the lens assembly is tweaked just a bit. Point it to your face and turn it on. Press on different places on the lens assembly while you toggle it off and on. If it comes out, your lens unit is out of line. You can try moving it side to side and even forcing it a little but it will probably never be just right.
Posted on Nov 29, 2007
SOURCE: Camera will not download pictures to Dell computer
Have you tried starting download manually? Control Panel > Add Hardware...
Posted on Jun 24, 2008
SOURCE: Lens stuck after dropping camera
Probably it can be fixed, but if the lens gears are too damaged the repair could be much expensive and you would prefer to buy a new one.
Take your camera to a qualified technician to check the price of a repair.
Posted on May 24, 2009
SOURCE: SAMSUNG S850 WONT TURN ON AND LENS IS STUCK IN OPEN POSITION
I had the same problem, Turn it on and wiggle the lens and it will become unstuck. Well thats what my problem was and that what fixed it. Good luck
Posted on Jun 02, 2009
SOURCE: samsung pl50 lense jammed?
Hi
Thanks
for using FixYa. Please check the battery is fully charged.
If you are able to access the Menu, please select Initialize under Settings and
Main Settings 1 Menu and press OK. If still the issue persists, perform
the power reset by removing the Battery and
pressing the power button continuously for one minute. Then, leave the power
button and reinsert the Battery.
To reset
the Digital Camera by using a RESET
button follow these steps---
To perform a manual power reset follows these
steps---
If still
the issue persists then it means that the cabinet is opened or LCD cable is
touched which is caused by connection defect or poor contact between connector
and LCD cable due to the pressure by the rib in the front cabinet to the
connector. If still its not resolved then as its a new one so you should use its warranty and get it replaced just to avoid future issues.
Please do
accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 05, 2010
May 22, 2010 | Samsung S850 Digital Camera
Sep 19, 2009 | Samsung S850 Digital Camera
Sep 05, 2009 | Samsung S850 Digital Camera
Apr 18, 2009 | Samsung S850 Digital Camera
Jan 18, 2009 | Samsung S850 Digital Camera
Dec 09, 2008 | Samsung S850 Digital Camera
Nov 13, 2008 | Samsung S850 Digital Camera
Jun 24, 2008 | Samsung S850 Digital Camera
Jun 19, 2008 | Samsung S850 Digital Camera
Feb 08, 2008 | Samsung S850 Digital Camera
50 people viewed this question
