Question about Samsung HT-DS1000 System
Problem with disc tray opening on its own.
I've had a random issue over the last couple weeks with my HT-ds1000 where I'm watching TV and all of a sudden the disc tray would open on my receiver, which changes the audio from Digital input to DVD - thus muting my tv show.
I thought this was a random thing until this morning.  In the last hour the disc tray has opened and closed on its own at least a dozen times, each time kicking me out of my tv audio input.  It's been turned on and off, and the power has been unplugged.  Neither has worked.
Suggestions???  I've only had the system for a couple years, and would be real disappointed if this thing is already crapping out - I had to stop using the internal DVD player because it got to where it couldn't go thru a full movie without freezing multiple times, even after going in for repair.
    Guru:
  • 155 Answers
The micro-switch that tells the dvd drive it is closed is probably faulty. On most optical drives of some kind if the device senses that it is not closed - the switch has not been pressed - then it will open it again because it thinks there is something stuck in it. There may be something in your device that is stopping it close or the contacts on the switch may be dirty or you may just have a faulty switch. This would explain the random opening of your drive.
Hope this helps,
Mowcius
Posted on Aug 03, 2008
  • 32 Answers
If you have got something stuck in it you need to buy a new one
Posted on Jun 26, 2008
Why does disc tray open randomly Samsung ht-em54c
I had the problem of the disk tray opening and closing randomly but finally fixed it. I went thru a number of steps so I don't know which combination or individual step fixed it but I think it was changing the HDMI cable from the TV to the Blu ray player that finally fixed the problem. Previous to that I had removed the disk player and got the audio to work with only the TV and used one of the HDMI inputs as the output from my PC. That way I could play DVDs on my PC and run it thru the player to get audio in the speakers and video on the TV. Every once in a while the tray would try to eject (even though the player was not there). Finally I changed the HDMI cable to an older cable, the one between the TV and the player and it started working! I then put the disk player back in the unit and it all worked, everything!! Good luck!
Jul 22, 2014 | Samsung HT-X50 System
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
I have an HT-DS1000 I bought used. The FM tuner works, the CD player works ok, but it will not read DVD's at all. It just continually says "loading." I hooked up an alternate DVD player...
Optical pick up out of tolerance. If you take disc out it should stop clicking. The clicking is the optical pick up lens hitting max extension due to focus not being achieved
Apr 25, 2017 | Samsung HT-DS1000 System
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
HT900
I kept hitting the disc exhange/eject button to turn the unit on and after a couple of tries it finally opened about half way. The whole reason i wanted to open it was to get the last dvd that i watch out of it. Well in doing so i noticed that there were some discs rattling around up underneath the cd tray (from my 1 1/2 year old). After shaking the unit a couple of times i was able to get the discs out of the underside of the disc tray. When i hit the disc exchange to close the try the unit powered up, closed the tray, and operated fine and i am back to using it like i used to with out any other problems.
Oct 15, 2008 | Panasonic SC-HT940 System
Dvd do not loads
Our started doing the same thing about a week after the warranty ran out. It has to do with the alignment of the discs being loaded. here's a work-around that works for us:
Open the tray
Choose which disc you are going to watch and use the Change Disc button to push the selected disc to the back (ie, if you want to view Disc 1, discs 3 and 4 will be visible in the tray).
Look down the center holes of discs 3 and 4... manually move your tray left-or-right to align the holes with the tray.
Push the Direct Play button on the top right of the unit for your disc of choice (Disc 1 using the example above).
hope that helps... I've searched for a while and played around with the unit (with and without the cover on) trying to figure out a way to re-align the tray, but no luck.
--JeD
Aug 20, 2008 | Samsung HT-WP38 System
Samsung ht ds1000 audio problem
I had the same issue 6 months after I purchased the unit. Worked with tech support several times. Finally they sent new woofer and that fixed it.
Jun 12, 2008 | Samsung HT-DS1000 System
Samsung ht ds1000 plays fine, but there is no sound.
you have not blown thye fuses the static sound suggests that that is not the problem
Jan 19, 2008 | Samsung HT-DS1000 System
Dvd does not load
clean the lens of your dvd if that does not work there is a strip connected to the lens have that replace or adjusted by a tech.good luck.
Apr 03, 2007 | Samsung HT-DS1000 System
Even when the DVD is in the tray correctly, it says "No Disc"
I had a similar issue and now mine is opening closing opening and then powering off?
Mar 18, 2007 | Toshiba SDK615 Multi-disc DVD Player
Samsung HT-DS1000 System Logo
273 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
