Question about Samsung DLP HL-P5663W 56" TV
Green picture I have a 68' Samsung DLP Tv and all of the sudden everything that is supposed to be blue or shades of blue now shows up as green and shades of green. What can I do to fix this problem? Thank you for your help!
  • brogers2333 Mar 26, 2008
    I have the exact same problem just come up on my old Mitsubishi WD52327. There are a lot of shades of green especially where blue should be. some other colors don't quite seem right either. Have you come up with any solutions yet?
I have the same problem, the service people indicated this a manufacturer problem, they are not calling it a recall, but requires up graded parts which could take 30 days or more to receive. He said if they do not receive the parts in 30 days they might replace the TV. My TV is a Samsung DLP 61 inch
Posted on Jan 18, 2008
What is the blue wire for on a samsung av cable..that has 5 connectors and is green where you plug it into the tv
What is the difference between component av cable and composite av cable
On the five wire cable, the red, blue and green are for the picture. The other two connectore are for the audio. Not all TV's have this type of input. The link above has information about the five wire and other input cables.
Jun 15, 2014 | Samsung DLP HL-P5663W 56" TV
Dlp tv color goes fuzzy and green
Its probably unrelated to lamp, take the lamp out, try it again and look into the lens, if its still very green the projectors electronics are failing. The projector generates pictures as 3 streams of info Red Green and Blue. It looks like the projectors red and blue electronics are failing, but the green is working.
Dec 14, 2013 | Samsung Televison & Video
I have a Samsung Hlr5667wax/xaa DLP TV and the screen has gone green/green plaid pattern.
when the color wheel stops the picture will be all over the place. and you will have lines when it starts to fail as its not going fast enough for the picture. wining sound is it wearing out.
May 29, 2017 | Samsung Hlr5667w 56-inch Dlp Hd Tv
Green Lines on Samsung DLP
Either bad capcitors, or (if you're lucky) the color wheel needs lubed up. Probably bad caps.
Jun 12, 2012 | Samsung Televison & Video
My Mitsubishi 1080HD model WS-55315 colors are not correct. The blue is good and the green seems to be, everything else seems to be a shade of light brown or tan. I thought maybe the red tube was bad but...
The tv have a problems known as a convergence pictures problems,it is dead.Tv have any colors lines like R,G,B mis alignments,also tv have any colors shaded shadows pictures or a 3D pictures look alike?Yes,than the tv have a convergence board problems and it is dead to causes all of these problems.The tv convergence board must have to repair like replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence pictures problems.The tvs shops repair a DLP tv convergence board will cost u like $300-$350 for parts an labors.
Sep 12, 2011 | Mitsubishi WS-55315 55" Rear Projection...
Green shade color on screen over tyhe program that is been broadcast
its a loose connections to you color amplifier RGB. cold solder in that board section.
May 30, 2009 | Samsung HL-R6167W 61" HDTV
54" Projection TV
Your green gun in our tv is misagligned/out of focus. Your tv uses red, green and blue guns that layer in different shades and mix to create the different colors. Your green is a little off so the colors aren't mixing right which explains the green haze and the shadows. A tv repair man can fix this problem pretty easily and it isnt expenisve.
Aug 28, 2008 | Akai PT4298HD Rear Projection Television
Green
carry it back.
May 19, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP TV- colors seem to mess up -Faces have green streaks
sounds like you are haveing an issue with th color wheel timing. either the color wheel is bad or the dmd board is bad.only way to know is to have a technician look at it.
Oct 22, 2007 | Samsung HCN4226W 42" Rear Projection...
Samsung DLP HL-P5663W 56" TV Logo
276 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
